Question about Amana Heating & Cooling
It is an amana window ac/heat ae123a35ma 11600 btu i cant hear the compressor start just get fan air no cool air
    Brigadier General:
  • 8,619 Answers
Hi
Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components.
If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas:
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 26, 2009
Fan runs. Why won't the compressor start?
probably a relay on module either bad or not communicating with thermostat.
Jul 12, 2015 | Coleman 15000 Btu Rv Roof Air Conditioner...
Any body tell me what is the problem with my 1.5 Dawlance split ac It gives perfect cooling in night and morning but in afternoon its compressor turn on and off every after 15 minutes. And due to this my...
when the heat ambient temps go up . the start capacitor gets hot to turn on fan and heat sensor for the compressor senses it and turns off . check the run/start cap first
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
HEIL HVAC, fan blows but no heat or AC
Your airconditioning system may be out of cooling gas, and if it has sufficient gas, the compressor might not pick when you put on the AC, and if the compressor did not pick ie start, you cant experience cooling effect, the fan will only be blowing.
Jan 18, 2013 | Cars & Trucks
Window air conditioner cools (very icy cool air) for a minute or two then switches to fan. Will then stay on fan for about 10 minutes and then once again get "very cold", but only for a minute or two
Before I even read that far into your post, I was thinking "thermostat" replace it...It seems to be failing badly. If you take it into logical perspective...normally the unit gets turned on, then takes a bit to get cold, then once it reaches its pre-determined temperature, turns the unit either "off" or just blows the fan...by kicking off the compressor. This unit you have is getting this cycle done within 5 minutes instead of a few hours...replace the thermo and you should be fine. Now if you could post the exact model number here I can go look up the part for you.
Jun 20, 2012 | Amana AH123E35AXAA 11,600 / 11,200 BTU...
Why is ge ajes12dcc 11600/11400 window air condition/heater combo blowing cold air for heat the air conditioner is working fine but the heater is blowing out cold air
Hi, it sounds to me like your reversing valve is not switching the flow of freon over to heat, stuck in cooling. The valve is located near the compressor, it has a 24 volt coil on it. If you unplug it, it should switch the valve into heat. If not, the valve is probably froze stuck, and will need to be replaced. Something a service tech would have to do.
Shastalaker7
Nov 06, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Working but not cooling
Check and make sure its on cooling mode and just not "fan only"
You should be able to hear the compressor start up a few seconds after the fan starts. One easy way to tell if an AC is working on cooling is it should be blowing hot air outside and cold air inside. If not, you may have a gas leak or the compressor is not starting..
Jul 14, 2011 | LG Electronic Window Air Conditioner
Kenmore 12,000 BTU Room Air Conditioner ENERGY STAR
How many Square Feet is the ac rated for?How large of room are you trying to cool??
May 27, 2010 | Heating & Cooling
I have a whirpool 17800 btu ac /heater that is not cooling
Troy, it may be simple cleaning job, starting by cleaning the filters, the condensing unit and check the fan that is moving freely, and let me know if that work if not we go to the next step. Please see that grant me your approvals by rating my service and I hope that I can serve you again the future. I will work with you in this issue to conclusion
Sep 26, 2009 | Whirlpool ACE114PP Heat Cool Wall Room Air...
Heather don't work
If the unit still works on cooling you might have a faulty reversing valve/ heating plate. If you are confident with a multi meter you could test if they have power going to it and see if you have a faulty part but it would be best to get some tech help out
Jan 07, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
21 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
