On my Mitsubishi DLP WD62827 set the color changes from one color to another after set is on for about 15 min. Once the color changes, like all the reds turn blue, it stays the wrong color. I'm wondering what the problem is and in general how much that kind of thing usually costs to get fixed.
  • centolam Jul 27, 2009
    Very helpful solution. Exactly what I was looking for. Thank you.
  • 10,594 Answers
Problem seems in DM board that consist of digital video signal processor and few other sections. That board can have lose connectors, dry solder joints on PCB. In that case it can be fixed around $200
Qualified TV tech will confirm after testing it and if DM board required replacement then it would cost you much like $750 plus.
Thanks.
Posted on Jul 26, 2009
Need advice on Mitsubishi DLP TV. It has black and white vertical lines.
Check out the color wheel - when those units go there is no color and/or all kinds of color anomalies with DLP sets only. Not cheap.
Jul 18, 2015 | Mitsubishi Televison & Video
I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this. Can anybody help me to find one
Mitsubishi HC1500 DLP Projector Repair Questions ... - Fixya
www.fixya.com > Forum > Multimedia Projectors > Mitsubishi
Recent Mitsubishi HC1500 DLP Projector questions, problems & answers. ... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
I have a mitsubishi hc1500 projector and it made a popping ...
www.fixya.com/.../t5370392-mitsubishi_hc1500_projector_made_poppi...
I have a mitsubishi hc1500 projector, when i went to turn it off it made a loud ..... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
MITSUBISHI HC1500 DLP 720p Home Theater Projector ...
www.newegg.com/Product/Product.aspx?Item...
Newegg
Rating: 5 - ‎22 reviews - ‎$949.99 - ‎Out of stock
MITSUBISHI HC1500 1280 x 720 DLP 720p Home Theater Projector 1600 ANSI Lumens 2500:1. ... If you are a high-definition video enthusiast who's looking for a more affordable way to bring a front-screen projection to your home theater or family room, the Mitsubishi HC1500 projector is
Dec 27, 2014 | Mitsubishi HC1500 DLP Projector
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
73 mitsubishi dlp tv 73737 has sound but no picture with red light in frount
You need a new lamp. The red light means the lamp failed to turn on.
You can find cheap ones on ebay for about $40. If you go to best buy they will charge an arm and a leg. You can change the lamp yourself and it will take less than 15 mins to do. The only tools youll need are a phillips screw driver and maybe a flat head.
Jan 26, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi 65 dlp
SOUND LIKE A BAD COLOR WHEEL...HEAR A LINK TO SEE IF THAT THE SOUND YOU ARE HEARING ....http://www.youtube.com/watch?v=hUiYRqrNxxU
Dec 24, 2013 | Televison & Video
Changes colors
This is a DLP projection. may be that you have a defective color wheel motor or supply voltage to color wheel motor is out of range.
daniel.acosta@codetel.net.do
Jan 08, 2009 | Acer PD525 Multimedia Projector
Mitsubishi 1080p 73'' DLP HDTV - Color distortion
This would be the little sensor on the light wheel. Its cheap, you can get them online for around $2. You will need to take the light engine out and remove the color wheel cover and remove the color wheel and then remove the sensor. You will have to desolder the sensor and remove it to replace with the new one.
What is happening is the sensor is overheating and not tracking the color wheel properly there for the colors get messed up. Once you replace the sensor the tv should work like normal. The part is
(Sharp GP2S40 Photointerrupter). It is very difficult to find because they are not made anymore. Most major online part stores do not carry them but I found a lot of them at Wright Hobbies. Good luck.
Nov 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Vertical line down the center of screen
A WD62827 is a V30+ chassis and is a DLP format projection screen Tv, not a flat screen, am I missing something?? For the symptoms you're describing with a WD62827 remove and reseat the DVI cable between the chassis and optical engine. If removing and reseating the DVI cable does not resolve the issue you may need to replace the Optical Engine part # 938P019020
BTW the current software version for this unit is 7.04.1F if you have anything less you might think about updating the software also..
Hope this helps!
Bill
Nov 29, 2007 | Mitsubishi WD-62827 62" Television
Color problem with DLP TV
If pic. is distorted when warm :. Suspect the FMT PCB part # 930B924002
Sep 24, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
