Question about Freezers
Sub zero 550 icemaker not making ice/not working
SZ model 550 icemaker won't work or make ice
    Sergeant:
  • 272 Answers
First off, make sure its under 17F in freezer as icemaker will not start above this...you need to make sure the icemaker is coming on..if so, you may just have a bad water valve. I'd put four ounces of water into the mold and see if it starts by itself dumping out your ice. if it dumps out your ice..look to see if the inlet tube that brings water into your i/m is not frozen up with ice in it..if it is, defrost with hair dryer and wait and see if it starts to work ok dumping ice.if it starts to work ok..replace fill valve..
If you find everything looking normal and your sure no ice plug in fill tube..you can try to start i/m manually..if your confident enough to work with tools and electricity...find the T and H they are close to each other on front of i/m. take an insulated wire and make a jumper that each end has 1/2 of end stripped of to go into i/m T and H..keep in there for 30 seconds and i/m should start on its own..remove jumper and either put i/m back or be ready to catch water should it come on. if no letters on front of i/m just gears. find the small 5/16 gear and turn until rake arm starts to come up. this i/m should start on its own ... if it starts and runs fills, replace i/m...if it starts , but does not fill..your inlet valve may be bad. it helps to have a volt meter for this.. you can remove top and find valve up there or its under the bottom front vent plate. locate wires that go onto valve. use your volt meter to check for 111-130 volts when you restart your i/m as already talked about. remember, it will take several minutes before you notice anything..the i/m needs to cycle first and get to the spot it fills..if you get power and no water and your sure there is water..the inlet valve is bad...
Posted on Jul 26, 2009
Sub zero ice maker jz235p0 specs
Call the mfr or ask them for the website that has the specs on it.
Mar 04, 2013 | Sub-Zero Sub Zero Icemaker
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
Sub Zero ice maker (Model 235) not making ice, warm inside
try first. condenser ciol clean. is the water cold? is cutter grid in god shape? the brackett under the evaporator is attached?
Apr 02, 2010 | Freezers
Ice maker is not making ice
Subzero ice makers arent all cut and dry. You could have an intermittent issue with either the ice maker itself, or the solenoid valve. SZs also often utilize a door switch which prevents the ice maker from operating if the door or the basket which the ice bucket sits in are not closed or in the proper position. If you have had other what would seem minor problems, that you have lived with, they can inadvertently affect different things. Most sub zero ice makers you can start manually by rotating the ejector comb clockwise as you look at the front of the icemaker, when the icemaker completes its cycle, do you get water to the ice maker, and do you get enough water, usually 140-150 ccs. If the ice maker continues rotating on its own after your initial start up, and receives the proper amount of water, either you have a cooling problem, a door or something is not in the correct closed position, you have a bad switch, or the ice maker is bad. If you receive little or no water at end of cycle, you have a bad valve.
Mar 25, 2010 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
Sub Zero 5065 Under Counter Ice Maker
We have a sub zero 5065 in our storage, still unused and in the box. You may want to just buy it at a good deal. Make an offer, it has to go as we are cleaning out the storage are. 360-695-3238 Brian
Mar 18, 2010 | Freezers
Sub zero refrigerator model 532 problem the freeze is warm on the top but the ice & items below the ice are OK. i suspect that the light may be always on. also the freezer door does not make its...
I suspect a bad fan motor, door switch, or not defrosting.The suction when door closes is caused by the low temperature created when working properly.
Feb 14, 2010 | Freezers
I have a Sub-Zero Model 501F freezer making ice cubes
Check defrost heater that goes into drain tube. When the drain freezes ;the defrost water spills into the icemaker.
Oct 08, 2009 | Freezers
10+ years old sub zero 550. ice cubes are green
I would not recomend using those ice cubes. Sounds like theres lots of mold or worse growing in your freezer. I would get rid of it. ;(
Jul 09, 2009 | Freezers
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Sub-Zero Under Counter Ice Maker not making Ice
ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Feb 20, 2008 | Freezers
Freezers Logo
735 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
