My 20V battery was stored completely discharged for over 8 months. After all that time I bet the battery was holding no charge whatsoever. When you plug a completely drained battery to a charger the charger will experience a big demand in current and will fault out, flashing red. So we need to put just a little bit of charge in the battery for the charger to start working. What I did is with the battery in charger unplug and plug the charger like 10 times. Every time you plug it in it will send voltage to the battery for a split of a second before the charger fails. Eventually the battery will get enough charge for the charger to start working.
SOURCE: my black and decker battry
Is it the charger or the battery? Have you tried other batteries? If the battery is bad (they do go bad over time) then the charger wont work. But chargers also go bad too and can't be fixed. I've had four Dewalt charges go bad over the years (same parent company)
SOURCE: Black & Decker LITHIUM CHARGER 14.4v to 18v . 90539541. fits A1518L, HP1884L
could be either one. Have you tried another battery? If not I would recommend taking BOTH in for inspection. They have a scanner that can detect if the battery has a problem. If you need to find a service center close to you go to dewaltservicenet.com and they have a locator. Let me know if you need more assistance.
This worked for me .. Put battery in charger , unplug and plug in charger repeatedly until it charges
