Question about Canon PIXMA MP830 All-In-One InkJet Printer
Lost power yesterday. Printer will not turn on.
How do I get the power to turn on?
    President:
  • 2,306 Answers
You can try removing the printhead to see if it turns on, if so, you need a new printhead, if not it will need a new logic circuit board.
Posted on Jul 27, 2009
Lost the remote to my akai tv was able to turn off and on yesterday i couldn't get it to turn off so i unplged it from the wall later came back home plug the tv back up and now the power light doesn't
Hi Tamara,
Mosty likely when you turned it off from the wall,it must blown the fuse because of the way it was shut off suddenly.
If you can open it up if not than take it to a qualified Tech to get it fixed.
thanks,
G..
Nov 21, 2011 | Akai PDP4294 42 in. EDTV-Ready Plasma...
My printer will not turn on it worked yesterday and i've done nothing different. could it be the "brick"?
Try to unplug the power adapter from the printer.
Check if it's warm or cold. It could be a defective power adapter issue. Unplug and replug the power cord into the power outlet to reset it. Bypass any surge devices or power strips. Replug the power adapter into the printer. The printer should automatically turn on, otherwise press Power button.
If problem continues, then it could be a faulty power adapter problem. I'd suggest you to contact Lexmark technical support for additional assistance.
May 17, 2011 | Lexmark X2500 All-In-One Printer
I had a power outage in my house yesterday and today my Canon PIXMA mp 560 printer will not turn on. I have tried plugging it to different outlets. There is simply NO response from the printer.
Chances are it has blown the main fuse in the power supply, and perhaps done some additional damage to some electronic parts. The printer must be dis-assembled to make that determination.
Feb 23, 2011 | Canon MP560 All-In-One InkJet Printer
Worked yesterday, now will not turn on!
  • Try connecting the printer directly to wall outlet without surge protector.
  • If the problem exists reset the print, see below steps to reset it.
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Riztech
May 02, 2010 | HP Photosmart 3210 Printer
Printer won't turn on. had power outage yesterday. now printer won't turn back on. have power to receptacle.
Sounds like a bad low voltage power supply.
You can google a business called The Parts Drop and contact them.
Dec 08, 2009 | Xerox WorkCentre M15i Laser Printer
OfficeJet 5610 Won't turn ON
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab6
Jul 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Sounds like power supply is cooked.
Apr 23, 2009 | Canon i860 InkJet Photo Printer
My printer won't turn on after a power failure.
No, there is no reset button.
disconnect the pirnter from the computer and the power cord. press and hold the power button for 30sec. connect the power cord, and connect it back to the computer.
Dec 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer will not turn on/power up.
unplug the power cable from the printer..
Press & Hold the power button for 60 seconds when unplugged from the power and release it..
connect the power cable to the printer and directly to a wll jack instead of the power socket and check..
Nov 03, 2008 | HP Deskjet 3845 InkJet Printer
Power Down
if you send a print from pc before the 2 minutes is over, does the printer complete the print before shutting down? the printer has somehow been forced into power-save mode. remove the power input for 15 minutes and then re-apply it...any change?
May 29, 2007 | Epson Stylus CX7800 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
81 people viewed this question
old marine
old marine
