The convergence is way off and will not adjust. Pulled and sent Sony the D board...new D board installed but did not fix the problem. Flash focus nor manual convergence will adjust. Have 3 images for red, blue and green.
    Champion:
  • 230 Answers
Hi, thank you for visit fix ya.
Do you replace STKs ICs?.
If so, you need go to service menu tv.
With you tv off, press on your remote control:
display + 5 + vol+ + power.
You will go to service menu tv.
NOTE: Be Careful before you do this, because if you don't know step by step convergence adjustments.....YOU WILL MESSED UP YOU TV.
I recommended if you don't have electronics skill, take the tv near to tv shop.
Any question I will be here .
( I need model number tv, please)
Thank you
Posted on Jul 26, 2009
Sony post convergence repair problem
The flash focus is a joke in these sets--only adjusts a limited area and can make the set look worse--like having a cigarette lighter in your car--not really needed.
Flash focus rarely if chips have been replaced will SAVE the adjustments.
The set stores the convergence adjustments on a board inside--best way to adjust is with the Sony remote to enter the tech menu and adjust there--when done one of the numbered buttons is pressed and Save? in red appears--press same button again and it goes to green which means adjustments have been stored in the set.
The tech menu will also always give a much better adjustment of the entire sceen.
Apr 14, 2012 | Sony KP-51HW40 51" Rear Projection...
The Flash Focus is not adjusting the convergence automatically. I have colors all over the place on the screen. What should I do?
Ur tv 100% have a convergence problems,it dead.The tv convergence board,the 2 STK convergence ICS and some are all it resistors are dead.These parts on the tv convergence board,must reqiure replacing to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 27, 2010 | Sony KP-53HS30 53" Rear Projection...
Sony kp 57hw40 Convergence Problem The screen looks distorted, Letters or words on the screen are bowed.(I can see double but the screen is stationary all the color, hue, sharpness, brightness, exc. can be...
If after the Flash Focus™ feature has been performed, the colors on the FLASH FOCUS screen do no line up (converge), press the FLASH FOCUS button on the television to begin the cycle again. If the colors on the FLASH FOCUS screen continues to appear misaligned, service will be required .
NOTE: It is recommended to perform the Flash Focus™ feature about thirty minutes after the television has been turned on and keep the room as dark as possible.
Sep 22, 2009 | Sony KP-57HW40 57" Rear Projection...
I have a Sony KP-51WS510 projection TV. The convergence was OK one evening, then way off the next day. I could not be adjusted. I pull the D board which has the convergence chip and sent it to Sony. I...
Hi, thank you for visti fixya.
Here is your solution:
Replaced, IC8001 and IC8002 Part number STK392-560 and check pico fuse beside STKs ICs ( yellow pieces), go to :
http://www.encompassparts.com/tritronics//
for parts.
I will be here for future questions.
Thank you
Jul 26, 2009 | Televison & Video
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Model Sony 61HS30
no, if touch focus didnt correct it, you will need to replace the convergence ICs
Mar 20, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-53HS10 lines flicker across screen
tap around on the circuit boards in the rear of the television. narrowed it down to the Comb Filter circuit board. It is the smallest upright circuit board behind where you plug in all your connectors. pulled it out cleaned it off, reinserted it
Jan 23, 2008 | Sony KP-53HS10 TV
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
