THe unit says high salt always
SOURCE: I have a 24x52 pool
For starters I would bring a sample of your water to a pool store and they usually test it for free. They will then make recommendations. Be certain that everything you add to a pool is necessary based on the test results. If you are draining or partially draing the pool then sometimes chemicals recommended by the pool supply store will not be necessary.
The following is what I would do to keep a pool blue:
1. Make sure salt is at the recommended concentration.
2. Only shock the pool to if the chloring level has droped below about 2 ppm.
3. Place the recomended dose of stabilizer in the pool.
4. Make sure pump and filter are working properly.
5. Check the pool chemistry on a daily basis for about a week to. I recommend test strips that at least measure chlorine, Ph and stabilizer.
6. Check the chemistry on a weekly basis and clean the pool and equipment according to the pool instructions.
Smile, you are a pool manager.
