Question about Maytag Neptune FAV6800AW Top Load Washer
I have an internal leak, how is the front panel removed?
  • 42 Answers
Hi
here is a link to the manual for your machine.
To remove the front panel of the machine you will need a 5/16 nut driver or 5/16 ¼ socket on an extension to remove front panel see page 41 of the service manual
cheers
Posted on Jul 26, 2009
How can I fix this?
Hello. There is an LE error that means "fill error". There is also a "tE" error that means "sump thermistor failure". You are probably getting the tE error--the thermistor is located at the bottom front of the washer tub in the center. If water is leaking from the bellow(the rubber part that seals tightly against the door), it might be spilling down onto the thermistor wires, shorting it out. With any leak, this will be an INVOLVED repair. My suggestion is to call for service--to reach anything in the front of the washer internally, the front panel must be removed--this is complex, and must be done carefully, especially if the bellow is leaking and needs to be replaced. I hope I helped you!
Aug 21, 2015 | Maytag MAH2400A Front Load Washer
My new lg washer delivered today is leaking water into the pedestal also is noisey and shakes
did whoever set it up, remove packing bolts from the back? is it leaking from hoses on back of washer, or from internal? check front panel on lower left from of washer. is filter accesses tight?
Mar 03, 2015 | LG Washing Machines
Hello, my Frigidaire heavy duty-extra large capacity-2 speed combination-3/4 hp motor washing machine has sprung a leak internally on the left side. How do I remove the front cover panel to troublesho
The easiest way to help you is to recommend you go to YouTube. type in Frigidaire washing machine disassembly. Repair Clinic has been the most useful for me. http://youtu.be/qcViH3Samp8 Good Luck.
Dec 21, 2014 | Frigidaire Washing Machines
GE side by side leaks water from underneath when you use the water from front door
you need to remove the toe kick panel grille below the front doors on the refrigerator behind this grille there is a connector and it can come loose,also possibly the water valve in the lower rear behind the back panel can leak,have a helper press the door paddle for water and check all these areas for leaks,if it leaks from the door stem where the water line goes up the door to the dispenser,then you will need to pull new hose up to the dispenser from the collar mentioned at first,some refrigerators can not have new hose installed due to the door has been foamed internally at the factory and cant be dis-assembled,then you would need a new door with the hose installed
Apr 08, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Removing trim panel in front of climate control module so i can replace the module without breaking trim panel
It prys out. What is issue/ All air coming out defrost? IF , yes, you may just have a big vacuum leak where the vacuum harness mounts to back of heater controls. 2 tie straps will fix it. I have pics. If internal vacuum leaks, there is Gino on ebay who fixes for $150.
Sep 06, 2011 | 2004 Mercury Grand Marquis
Washer leaks after it starts to agitate. It seems to be coming from the front of the washer. Thanks for any help.
To find where the leak is coming from, remove the 2 bottom bolts on the lower kick panel and remove panel. Next, remove the 2 bolts holding the upper front panel and remove it also. Now, with the front panels removed, run the washer and look for where it is leaking from. Repost your observations.
Feb 11, 2011 | Maytag SAV365ZAWW 3.3 cu.ft.
LAT 7793 ABL model number. Washer leaking during fill...? a seal or gasket but not sure how to remove the spin bars to access it
On Your washer to locate a leak, remove the front panel first. Should be two clips at the bottom of front panel, use a putty knife to pry them down while pulling lower of front panel forward (older models used two screws right through front panel on left and right sides). After getting both lower clips loose, pull bottom of front panel forward to remove from top.
Set front panel aside and then use a 3/8" socket or nut-driver to remove two screws (one each) in the front right and left corners that secure the top to the side panels of the washer (inside in front corners going upwards). After screws are removed slide machine away from the wall about 8-10" and lift front of top up. Will pivot up like the hood on a car. This will allow you to examine machine for leaks.
Let me know when you come up with leak location if you need any more help!!
Jun 30, 2010 | Maytag LAT3600A Top Load Washer
BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Jun 30, 2009 | Washing Machines
Water leaking from hot water connection
Try sliding the panel backwards it should slide off.. Hopefully this should do the trick
Apr 26, 2009 | LG WM-2277HW Front Load Washer
Leak
it may be the valve assy.theres probably no holes anywhere because it would leak all the time.remove the wrapper assy lift the control panel two screws at the front then remove two spring clips under the control panel undo lid swicth plug.and and lift wrapper off.then you can see valve and internal hoses if your model fills up from a chamber at the front corner see if it over filling while filling.hope this helps.
Mar 17, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Neptune FAV6800AW Top Load Washer Logo
209 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
