Question about HP DesignJet 755cm InkJet Printer
Printer prints in mirror image. How can I resolve the problem to print normally?
  • 1 more comment
  • arnelfc Jul 27, 2009
    It didn' t help.
  • arnelfc Aug 01, 2009
    Where can I find that MIRROR word in the page format menu? I have opened this menu and there's nowhere to find it.
    not at this time
  • 339 Answers
Go to the Page Format menu and deactivate the Mirror feature if it's been accidentally selected. It should also clear out if you cycle power on the plotter.
If this doesn't work, check your printer driver settings to see if mirror is selected there.
Posted on Jul 26, 2009
  • ted1430
    ted1430 Jul 27, 2009
    What OS are you using and what software are you printing from?
    As a check, try printing something really simple like a one page Word document and see if it comes out mirrored.
The printer is printing mirror image which is upside down
You give scant information on your printer, listed under Operating System problem ... so this is a shot in the dark.
Open your printers Properties. Look for a "print mirror image" feature. Turn it off. I would reboot and then try to print. You may choose to select "print test page" to see if the problem is resolved.
Thanks for your question at FixYa.com
Feb 03, 2011 | Computers & Internet
My Printer HP Deskjet D2300 is printing in mirror image format. how to release the problem to normal method
Issue After downloading and installing Windows XP Service Pack 3 on the computer, the HP product prints text and images backwards or as a mirror image of what appears on-screen when printing from any program. Solution To resolve the issue, turn off mirror imaging in Printer Preferences . To do this, use the following steps:
  1. From the Windows taskbar, click Start and then click Control Panel .
  2. If your computer is in category view, click Printers and Other Hardware , and then click Printers and Faxes . If your computer is in classic view, click Printers and Faxes .
  3. Right-click the HP product from the list of printers, and then select Properties . The Properties dialog box displays.
  4. From the General tab, click Printing Preferences . The Printing Preferences dialog box displays.
  5. Click the Advanced tab.
  6. Under Printer Features , click Mirror Image , click the down arrow to the right of the field, and then click Off .
  7. Click OK to apply the change.
Trust this helps. Please vote. :)
Dec 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Print is coming out reversed
Somewhere in printing preferences, in control panel, and printer properties, there's a selection for mirror image printing for t-shirt stencils and the like. You just need to turn off mirror image printing and it goes back to normal.
Nov 06, 2009 | HP Officejet Pro L7680 All-In-One Printer
Print mirror image gel printer GX700
The mirror image setting is in the printer properties/ printing preferences. You can either go to control panel/printers/properties, or when you press print, and the window pops up, in printing preferences you can choose the mirror image setting.
Oct 13, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing in Mirror image
It's likely that you have an old outdated printer driver for your L7590 as this has been a long "known" issue with the L7000 series of MFD's.
To resolve the issue properly you need to uninstall the current driver version and then download the latest version of the software that isn't just driver/basic based.
You can extract the source files including the drivers folder using 7zip if you want to try and avoid installing all the additional bloat that comes with these printers.
Failing that, you need to define alternative quick settings to take over from duplex (two-sided) printing as this appears to have been incorrectly set to use mirror printing. Other quick settings have been implicated as well but the driver update should resolve all of them.
In some instances the driver update doesn't apply properly so you may need to uninstall and reinstall more than once... Remember to delete your printer from the printer listings and unplug it from the USB cable before you uninstall and reinstall to get it to work properly.
Hope this helps.
Martin
May 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
Mirror Image printing
This is caused by an early driver version provided with the printer.
Download the latest version from the HP website, unplug your printer from your computer then uninstall your existing driver. Once that's successfully completely install the new driver version.
Unfortunately this doesn't always resolve the problem straight away so you may need to repeat this.
To check if you've resolved the problem:
- Go to START > Printers & Faxes
- Locate your L7780 printer
- right click and choose "printing preferences"
- choose the "Two-Sided (Duplex) printing" printing shortcut
- click on the "Advanced" tab
- look at the setting for "Mirror Image"... If you've succeeded this should now be set to "Off"... If it's "On" you still have a problem.
The problem itself is caused by some duff default settings which seem to stick whenever you've done anything that uses the "Two-Sided (Duplex) printing" Printing shortcut provided in the printing preferences.
In particular I've seen this crop up with PDF files...
The new driver does seem to resolve this but a further work around is to define a new duplex setting that has the correct "Advanced" settings and has "Mirror image" set to Off.
This solution also works for the K5400, L7580, L7680, etc...
Feb 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
MY HP OFFICEJET J5780 is printing backwards
Open up any document.
Select File>Print
When the Print window opens, click on Preferences.
Click on the Advanced tab.
Look for a Mirror Image menu item.
If it says ON click on it and change the choice to OFF.
Click OK.
Click Print.
Jan 18, 2009 | HP Officejet J5780 All-In-One InkJet...
Prints text backwords on text files
click on start go to control panel
click on printers and under printer look for the printer icon
right click on the printer icon for your printer and select printing preferences
click on advance and look for mirror image
turn off mirror image and click apply
try to print afterwards
Oct 20, 2008 | HP Officejet J5780 All-In-One InkJet...
Printing backwards
When you get the print window, click "Properties", then click on the "Advanced" tab. Look for a "Mirror Image" menu item. It should say "Off". If not, click on it and you should get a drop down box to change it to off.
Oct 15, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Mirror image
Printing Iron-on Transfers
Load the iron-on transfers.
With your document open, click File, then Print. The Print dialog box appears.
In the Print dialog box, click Properties, Preferences (or Options).
Select a print quality:
In the Print Properties dialog box, click the Quality/Copies tab.
From the Quality/Speed area, select Normal or Better.
Select a paper type:
In the Print Properties dialog box, click the Paper Setup tab.
From the Type area, select Iron-on Transfer.
If your software program does not have mirror or iron-on settings, select a print layout:
In the Print Properties dialog box, click the Print Layout tab.
From the Layout area, select Mirror.
Click OK.
To print your iron-on transfers, click OK.
NOTE: To prevent smudging, remove each iron-on transfer as it exits the printer and then let it dry before stacking.
Mar 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
HP DesignJet 755cm InkJet Printer Logo
54 people viewed this question
Ben Johnson
