Question about Uniden DECT 6.0 Cordless Phone ID
On one of the two phones, the green send button,
On one of the two phones, the green hsend button, does not work. When you enter a number or answer the phone you have to push the speaker button. If you want to not have on speaker, you press speaker button again and it is private. The green send button does not do anything during the call either. Did I do something to cause this or is it broken?
  • evansgrammer Jul 27, 2009
    The phone is only 6 months old and rarely used. I use my cell. Only have the line because of security system requires a wired line.
  • evansgrammer Jul 28, 2009
    the phone is a Dect 6.0. It is black and sleek looking. Not the one in the picture if that makes any difference. I haven't any young children around and no one else uses my phone.I just can't think of how it could be damaged. I usually use the speaker phone button to dial. I guess I will have to take this in for replacement as it should be under warranty. I hope. Thanks for trying.
    Sergeant:
  • 277 Answers
Wellcome,the green button just damage due to frequent pressing of the button and you need to change the key pad interface before it will work fine.
Posted on Jul 26, 2009
  • femi john
    femi john Jul 27, 2009
    wellcome,you can not predict an electronics,anything can happen to it at any time,you need to change the key pad interface.
I cannot get a dial tone. I press the talk button to dial out. After 3 quick short beats a message appears in the display window " can't connect ". The phone rings when in coming calls come, but...
Which make and model of phone is it?
Are you pressing the green call button beforew you try to enter the number you are calling?
You should enter the number first, then press 'green'
You wont hear a dial-tone like a landline phone
Feb 23, 2011 | Cell Phones
Why is it that i cannot send and receive messages to my Nokia N95 Celphone. it says that memory is full and i need to close some application.
most probably it has a virus so try to scan your phone using the anti-virus of yours and if still doing the same thing i think you need to reset your phone to its factory default by doing this:
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the "*" button, and the number "3′ button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Oct 04, 2010 | Nokia N95 Cellular Phone
Can you supply an unlock code for my nokia 95
manual method to hard reset/format Nokia N95: + Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
Sep 09, 2010 | Nokia N95 Cellular Phone
I have nokia E63 when i tried to activate the security code when i enter the pin code the mobile is automaticaly lock.
Jun 24, 2010 | Lands Phones
I forget my n 73 lock code
Turn off the mobile device.Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Jun 11, 2010 | Nokia N73 Cellular Phone
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
Soft ware problem for nokia 8gb
if you reset,U'L LOSE AL YOUR DATA.
so try this only if you dint find any other way out.
plz dont forget to rate this if this was helpfull..
have a nice day
Oct 14, 2008 | Nokia N95 Cellular Phone
Nokia 5500 Sport camera not supported
Hi Debs
The soft-format code for Series 60 phones is *#7370# . You enter this code as you would enter a phone number in the Phone application. It performs a format of the Internal drive - All data will be lost if you use this feature.
The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows:
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and '3' button
While holding these buttons, press the power button and switch on the phone
When the message 'Formatting' appears on the screen, release all of the buttons
Aug 19, 2008 | Nokia 5500 Sport Cellular Phone
3-way calling
you have to press the send (green button), then type the number you want to call, then you press the send button again and when you hear it ringing or if they answer press send again and there ya go.
Nov 26, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Uniden DECT 6.0 Cordless Phone ID Logo
145 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
