Techwood 32'' LCD, screen is black, no sound.
There is a slight illumination when you turn the TV on - i.e. you can notice the difference between the black screen when it is on and when it is in standby.
The standby button illuminates, but cannot get a picture or sound.
Any help appreciated.
  • 585 Answers
The light you see is the backlight, you have either a bad signal board or tcon board which is part of the screen usually.
only cheap solution may be if the capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1
try reseating the thick cable running to the panel (Tcon board) top center inside the set
Posted on Aug 01, 2009
The screen will turn black but you can still hear it
This sounds like it may be a problem with the high voltage power supply that provides power to the fluorescent tubes that illuminate the screen.
Feb 15, 2014 | AOC Envision L32W461 32 in. LCD HDTV
My Element 32 inch tv has black screened.
hope I dont sound too crude, but have you checked the contrast and brightness controlls ?? they may be labled as 'picture options' or some other odd label...
does this tv have a LED, LCD or the older CTR display ?? If it is LED or LCD, then the light source that illuminates the screen are not working.. this light source could be damaged..
Sep 09, 2012 | Televison & Video
Sharp 32 in lcd tv has small horizontal black lines throughout whole tv
a model number may tell me more===trace lines at a slight angle?
More information needed here----
Mar 23, 2012 | Televison & Video
32" Element HD LCD TV screen often sticks to one
The tv have a long board called a LCD inverter board it is dying.This LCD inverter board help the tv LCD screen panel to have a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish a new long LCD inverter board for the replacement.
Oct 09, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Techwood LCD TV - picture fault
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Mar 29, 2017 | Televison & Video
Slight Hum when tv is off
Doesn't sound like the tv is off...I would contact the company.
Jul 11, 2008 | Sylvania LC320SS8 32 in. LCD Television
My Sharp LCD 26" TV shows most black and shadow colours as vivid blue, I have tried resetting the colour to factory reset but that didn't seem to help at all. It occurs on all channels and on 3...
the problem with LCD tvs are that they have back lamps that shine thru the LCD sceen. the job of the screen is to block the light of the different colors to make the picture. the problem is that the very thin screen can not block all the light. if the set has a back lamp setting turn down the back lamps and adjust the brightness control it should help a little. you my notice that the blacks and dark sceens look better when the room is fully lit and look much worse in a darken room.
May 27, 2008 | Sharp Televison & Video
Difference in contrast noticed when screen is black
If it is an LCD TV, then there may be lighter areas due to the location of the display backlights.
Areas closest to the backlights will be slightly lighter.
Feb 18, 2008 | Televison & Video
Televison & Video Logo
309 people viewed this question
Top Televison & Video Experts
Electro Med Services...
