Question about Dishwashers
I have a Kenmore model 665. It is having an intermittent problem. It goes through the fill cycle, and then stops. Timer does not progress either. Then, at some random moment, it will come back on and finish the entire cycle. This could even be a day or two later. Sometimes it seems a nearby thump will set it off, other times no one is anywhere near it when it comes back on. This happened for a month or so off and on 6 months ago, and then it worked fine for 6 months. Now it's back to it. Anyone have any suggestions? Thanks.
    Sergeant:
  • 272 Answers
Its possible its a door switch thats causing this or the main wire is loose..be careful as you do have 115 volts. i'd turn off power and check where power comes into d/.w and make sure the wire nuts are tight.. the next step is a little more difficult. you need to get into control housing area and check for loose or bad wiring. find , locate, repair, or replace switch if bad..
Posted on Jul 26, 2009
Dishwasher leaks during fill cycle
Just to be sure..take a look on that tube..it shoul be easy to remove the side pannels ..
Jul 01, 2013 | Kenmore 665
Kenmore dishwasher 665-1703 wont stop washing
Unfortunatly you are looking at the timer which is now built into the controller which would need to be replaced. If the relays are fused shut on the timer or the gears are missing some teeth then you will only get sofar I the cycle and the washer will just stay where it's. Sorry
Sep 08, 2012 | Dishwashers
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Intermittent spin cycle on Kenmore 90 Series washer
    You may try the speed selection switch.....Ive had problems with these.
    Jan 23, 2008 | Washing Machines
    Kenmore model 665 dishwasher
    the timer is bad.the 42 min cycle and the 6 min cycle share the same timeline.try northernparts.com for the part number and price.installing the timer isnt that difficult.
    Jan 05, 2008 | Kenmore 24 in. 16304 Built-in Dishwasher
    Dishwashers Logo
    Top Dishwashers Experts
