I have a Brother DCP110c and it says unable to clean checked the manual. but all that says is swith off machine and wait then turn on again but this does not work.. can anyone help please. Rob
    President:
  • 2,306 Answers
Unable to clean usually means the waste ink container is full, needs to be replaced by a shop, and count reset.
Posted on Jul 27, 2009
Unable to clean
Hi lobispo41,
If you are getting "Unable to clean" message from your Brother printer kindly refer on the steps below to address the concern:
1. Turn off the machine.
2. Turn the machine ON while you are pressing the MENU button. wait until leds flash. This time you're on maintenance mode.
3. Press 80.
4. Then, press MONO START button until you see "purge:xxxx".
5. Afterwards reset the purge counter by pressing 2783. Purge:0000 will appear.
6. Press STOP button.
7. Finally, exit the maintenance mode by pressing 99.
You can now go ahead and use the printer once again. The prompt should be gone after doing these steps.
Hope it helps.
Thank you for using FixYa,
Apr 29, 2011 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean error message
just swith of the printer even the swich of the main switch where the printer's plug is connected wait for 40 second then power it on again it will start working again if everything is connected perfactly
May 07, 2010 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
If you look at the Brother website, you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the print head is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck peice of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code soemwhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Nov 12, 2009 | Brother MFC-440CN InkJet Printer
Unable to init appear on the lcd screen. after i replace the black ink. what should i do?
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000002258&Sympt=How+do+I+clear+the+message+Please+Wait+%E2%80%93+Unable+to+Initialize+from+my+Brother+machine%E2%80%99s+display%3f+(pls%2c+init)&Model=22&ProductGroup=5&Keyword=unable%20to%20init&ProductID=DCP110C
Mar 28, 2009 | Brother DCP 115C All-In-One InkJet Printer
Brothers printer mfc 420cn
Here is the Brother solution page, you may find answer here:
http://www.brother-usa.com/FAQs/faq.aspx?Model=22&ProductGroup=1&Keyword=errors&ProductID=DCP110C
Please remember to rate all Techs who assist you for free :)
Oct 03, 2008 | Brother DCP-110C All-In-One InkJet Printer
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 110C printer error
you cant clean the waistinktank because when the felt dries up it wont take up any ink anymore! The rejected ink will flow into machine and cause serious demages!
Anyway you have forgotten to reset the eeprom code to tell the machine thta the ink absorberbox has been CHANGED!
Search here for error 46
Feb 15, 2008 | Brother DCP-110C All-In-One InkJet Printer
Printing blank page
I have the same problem, does anyone know what I can do. I have tried cleaning the head but it doesn't work.
Feb 07, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP110C Instalation Disc
download software + driver package from brother homepage of your country
Oct 27, 2007 | Brother DCP-110C All-In-One InkJet Printer
146 people viewed this question
k24674
jasbo
jasbo
