What electrical values does each utilize? I am trying to utilize a smart Relay driver from my solar system to communicate the start and stop of the generator as an override to the primary utility failure or restoration as a way to start and stop the generator.
From your statement you are a diy playing with electricity
that is ******* and dangerous
if you do not get it right , damage to the generator will result, somebody could get electrocuted and the utility supplier could have you for damage to their system
all you have to do is call in an accredited electrician and the job would be done in 10 minutes safely
while it is possible to set up that way that when the utility power fails, the gen set starts so that solar power can still be used in the house
it requires relays and circuit breakers and more that what you have in your description
SOURCE: Generac Guardian 15kW Generator
That sounds just about right, if the relay contacts get welded together it sometimes takes out the driver on the printed circuit board. As you found out, 12vdc from 23 to 194 makes the transfer switch move to the Generator position, relay not energized makes the ATS move to the Normal position.
You can make a nice test function by installing a 10 amp contact switch in series with either the N1 or N2 terminals. When the switch is open the generator thinks the Normal power has failed.
Regards,
Carl
SOURCE: HONDA GENERATOR PROBLEM
The armature (rotating field) is powered by the voltage regulator for 'excitation' which is the term describing a magnetic, revolving field. This magnetic field 'induces' voltage into the stator windings (stationary outer winding), producing voltage for use at the recepticles. Some older generators used a 'permanent magnet field, instead of using a powered winding from a regulator and the voltage and frequency were set by the RPM.
Frequency is still a function of RPM, but the voltage is controlled by the voltage regulator.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Asco transfer switch does not
Same problem here with the ASCO 165, after a couple of fierce lightning strikes yesterday that did over $10k damage to my neighbor's electronics, and also took out my garage door opener.
I'm pretty confident the control board is the problem, but I don't plan to try to replace components. Will probably opt for a new control board from ASCO, or another source, assuming they are still available.
SOURCE: Just finished installing a 20 KW Generac generator
Check the connections on the tranfer relay and two coils. The two coils have blue wires. I have seen them come off from assembly or shipping its common. Each coil has two blue wires #8 and E1 with crimp steak ons and limit switches make sure there all pushed on all the way. Hope this helps
SOURCE: I am installing a 20kw Generac generat or, how
You need to pull in two yellow wires called N1 N2 for sensing 220v. One red and one white called 23 and 194 those are your 12vdc transfer wires. And then last of all your 12vdc from battery charger. Hope this helps
