SOURCE: Water Leaks from bottom of machine as coffee is dispensed?
I had this same problem. Open the front door, remove the dreg drawer and then remove the brewgroup. In the back you will see a pipe sticking down with an o-ring gasket on it. Below that is a channel and a little opening where rinse water is supposed to flow into the front drip tray. It gets clogged with grounds pretty easily. I filled a hose with some water and stuck it down there and blew through it until you can see water come out the front hole. It's a little hard to describe but I hope this fixes your problem, it did for me. I just have to do it once every couple months.
SOURCE: Water in the drip tray of coffee machine
take out the mecanism and clean it how is instructed in manual, than get it back carefuly. Pay attention on position of mecanizm.
SOURCE: Gaggia is now about 10 years old. It works uo unti
HI
That is a stripped thumbscrew. You need a new one. When it starts to brew, the stripped thumbscrew pushes up and allows the coffee to fill the head and dredge drawer.
The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. It holds the filter screen in place. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that’s the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it’s a thumbscrew, so it only needs to be finger tight. The key is for removing only.
SOURCE: I have a gaggia deluxe coffee machine which won't
it can be 3 problems, you can eliminate them 1 by 1 in this order:
