Question about Dometic Rooftop RV Air Conditioner
My rv air tripps breaker aftr 10 min or so only on warm/hot days
On a warm to hot day my air starts to trip the breaker, we have checked the load on the breaker, if you let it sit for alittle bit and turn it back on the line amperage runs about 17-18 amps then gradually works up to around 22-23 amps before tripping. any help would greatly be appreciated
  • kgjohnston Jul 27, 2009
    checked supply voltage, was a bit low 108v, i switched breaker positions, the other line was running 117v, I have a 50 amp, 220 service, anyhow after switching positions the supply line votage for the air was at 115v, but the amperage was still climbing albeit a little slower now but it did finally trip at 25 amps. now remember this is while it is hot outside 100 deg . right now it is only about 79-82 deg. and night time and it is holding steady at about 15-16 amps.
    we pulled the cover off checked evap. and checked inside condenser everthing is clean.
    President:
  • 1,865 Answers
I suspect that your unit requires a 30 amp circuit. If it is running at 17, motor loads require 125% which is 21.25 amps. Conituous duty (means that the unit runs for 3 hrs or more) also requires 125%
You should be using a 30 amp circuit.
Posted on Jul 27, 2009
  • Dometic Master
  • 6,674 Answers
Compressor is working hard, and is probably caused by dust & or dirt in evaporator coils & fins, provided your incoming voltage is high enough to begin with. You should have no less than 115-120 volts to start. Remember, low supply voltage, causes higher amperage draw. One common problem if your in a park & at the end or near end of a power run, once everyone else does the same, your incoming voltage could be low to start with. 17-18 amps when leveled off and running is pretty high. Start-up, maybe, but not once up & running. Are you plugged in directly to pole or power source or is there another extension cord there?
Posted on Jul 26, 2009
  • 1 more comment
  • Mike Butler
    Mike Butler Jul 26, 2009
    If this helped, Please take time to check rating when satisfied please & thanks.
  • Mike Butler
    Mike Butler Jul 27, 2009
    Then my next question has to be, when was a thorough service cleaning done on this unit, as in top off on roof and washed inside?
  • Mike Butler
    Take a real close look up inside where filter is on ceiling for dust in coils/cooling fins. The dust tends to turn like mud when damp from condensation/humidity hits it, and will plug up. Not hard to do service on rooftop if your up to it.
Aircon tripps circuit breaker
Usually a short in the system or its drawing to much power for the breaker to handle. most common cause is a bad capacitor, Locked up compressor or compressor has gone to ground.
Aug 30, 2014 | Dometic Rooftop RV Air Conditioner
MY AIR CONDITIONER WILL WORK GOOD FOR ABOUT 10-12 HOURS AND THE NEXT DAY I WILL AND CHECK THE RV AND THE CIRCUIT BREAKER WILL HAVE POPPED WHAT WOULD CAUSE THIS TO HAPPEN. IT COOLS GREAT. THANK YOU
most likely the condenser is very dirty and the compressor pull more amps than is suppose to and when this happens the breaker tripps.start by cleaning the condenser with a design conderser cleaner.
Aug 12, 2010 | Dometic Rooftop RV Air Conditioner
Unit shuts off on hot days
It may be low on refrigerant. On hotter days, the compressor has to run longer to reach the temperature you have on your thermostat. Have it checked for the proper refrigerant charge and have them test how many amps that the compressor is pulluig as well. With the proper breaker installed, the unit should not be tripping out. Make sure that the breaker that is in there now is actually the proper one for your unit.
Best regrds, --W/D--
Aug 01, 2009 | Dometic Rooftop RV Air Conditioner
Breaker trips on roof top RV A/C
check your breaker is it hot to the touch?
check the wire tightness at the breaker?
remove the circuit breaker and inspect the terminals on the breaker and in the panel and the breaker itself for signs of overheating and discoloration due to the fact
check the connections at the unit itself
check that you have proper voltage to your unit
find the nameplate and look for FLA full load amp draw
is the breaker properly sized for the unit and is the wire size correct for the breaker?
(Check nameplate on unit)
buy a clamp on amp meter and see if it is under or over the nameplate rating when unit is running
take great care when you venture into electric,if you arent comfortable find someone who is.
you may have a weak breaker if all the above pass?
Replace it
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
A/c tripping breaker during peak heat of day ,coils clean,filter clean,pulling about 16 amps while running 15000 btu straight cool
Chances are you have a bad breaker or loose wires on the breaker. What size breaker do you have on unit. Heat of the day plus full load on the unit could cause it to trip. Rus
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
Dometic rv air conditioner over 100 deg. trips breaker.
The problem is that when u add up the electrical draw from all of these appliances running full bore, your draw exceeds your available amperage. Now you are doing the math and saying no...... Let me tell you why. It is rare to find a situation where a 100 amp service actually porovides 100 amps. You almost always have voltage dropo. And when you are adding extension cords to the mix the drop is even more. That said, When you are using the AC try to minimize the use of other appliances, especially the microwave which is a big draw too.
Jun 25, 2009 | Dometic Rooftop RV Air Conditioner
Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
May 10, 2009 | Dometic Rooftop RV Air Conditioner
My duo therm air conditioner works fine in the moning
If the unit has been serviced recently and they added refrigerant to it, then it's possible that they overcharged it causing it to have high head pressure which will increase the amp draw enough on a hot day to trip the breaker.If the unit hasn't been serviced, you might won't to check the condenser coil to see if it's dirty, if its not dirty then check the voltage to the unit, if you're in an RV park when everybody there is running there ACs the voltage may be to low for your unit to run. What fan speed are you running on you may need to run it on high speed during the day.
Apr 24, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
62 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
