Question about Mitsubishi VS-45607 45" Rear Projection Television
TV looks like it's in 3D
I have tried to use the convergence feature, but it doesn't even get it close...Could there be another problem???
  • Mitsubishi Master
  • 1,229 Answers
You may have to resolder the convergence ICS. Carefully remove the board to do this and while you are at it check all electrolytic radial caps. Looks overwhelming...patience my friend...If you can, an hour a day is plenty of time to do this. It may take a few weeks....trust me , patience is your best company. This is a good place to start! [Yawn!}
Posted on Aug 02, 2009
Tv is in 3D blurry format
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Sep 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I finally got my tv hooked up. but the color and the picture is blurry, mostly on the top. i have tried different things but no matter what it doesn't change the blurriness,and some lines come across...
Tv have a R,G,B colors lines misalignment,have picture shadows or 3D picture look alike?Yes,than tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair,by replacing like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 13, 2011 | Toshiba 57H81 57" Rear Projection...
Everything looks out of focus and the color hue is really bad. how can i fix this
Tv have a problems known as a convergence problems.The tv convergence board it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to fixed the tv convergence board to solved the tv convergence picture problems.U have all the tools and also can do ICS chips soldering?Yes,than tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a tv convergence kit that belong to ur tv make and model and repair it ur self.Or the shop will cost u like $300-350 for parts and labors.
May 07, 2011 | Mitsubishi VS-50605 50" Rear Projection...
I have a philips projection TV and it looks like a 3D screen without the 3D glasses. I tried converging the red & it is aligned with the cross hair. The blue convergence does not move. What can the...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2011 | Philips Magnavox 51MP392H Rear Projection...
The tv looks as though Im watching 3D. Tried unplugging for 5mins. Tried resetting picture settings nothing worked. Help please...
Very commom problems on the DLP tvs.The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300- 350 for parts and labors.
Jan 11, 2011 | Hitachi 53UWX10B 53" Rear Projection...
My picture is awful! lines don't seem to converge even when I try to do it manually. Everything is doubled. Can't even read the score when there is a basketbal game on! Any ideas or help would be...
Ur tv is 100% have a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-55819 55" Rear Projection...
My tv looks like it is in 3D without 3D glasses,
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV LOOKS LIKE ITS 3D
One might think that 3D would be a good thing but I am assuming that the problem is that it looks 3D without the glasses or in other words horribly fuzzy. If this is so you should be able to adjust the convergence in the set up menu to resolve your issue.
Feb 26, 2009 | RCA P61927 61" Rear Projection Television
The picture looks like it's in 3D
Your convergence is off. You should have a convergence adjustment feature on the menu screen. Very easy to follow.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Zenith projection tv model r45w46
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 02, 2008 | Zenith R57W46 57" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
91 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
