Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side refrigerator model tfx20jrx ice wont dispense
Ice dispenser will not dispense ice motor hums but i can turn it freelu tried running it without ice tray and motor does not turn do you know what the problem is and what it might cost for parts thank you Mike.
  • GE Master
  • 4,654 Answers
If the auger will move freely with ice out of the pan then the auger motor may be defective. Sometimes the connection in the door switch is defective. When the door is closed the switch turns the circuit on to the auger and control panel. Because the auger uses more amps that the water dispenser the door switch may be the problem or auger motor is just worn out.
Posted on Jul 26, 2009
  • 1 more comment
  • John Tripp
    John Tripp Jul 26, 2009
    Here is a link to the door switch.
    WR23X10161 Door Switch To look at parts place model number PSS26MSRASS into the parts and model search feature and click FIND IT.
    PART NUMBER AND MODEL SEARCH FEATURE I will be here if you have any questions, Thanks, Sea Breeze
  • John Tripp
    See you posted a different number than the one above your post.
  • John Tripp
    Mostly same door switch is same just use TFX20JRXAAA for model number, Sea Breeze
Ice wont come out of the door dispenser. Ice mover motor wont ru
take the bucket out of the unit to make sure the bucket is not frozen stuck. then it it still does not turn the motor, i would guess the dispenser motor is locked up and needs replaced.
Dec 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GSH22KGPCC model GE side by side. The drive mechanism does not seem to rotate. When trying to dispence ice it just hums. Other wise the ice makes works and so does the water dispenser.
You may have a frozen (literally) auger motor. If you warm it up and dry it out, it will run, but it will freeze up again. If this is the case, you will have to replace the auger motor and install a motor sheild over it.
Jul 07, 2009 | GE GSH22KGPBB / GSH22KGPCC / GSH22KGPWW...
GE refrigerator GSS25JFMCWW not dispensing ice but dispense water
I have the same problem with the same unit. I removed the ice tray and held the open door cut-off switch closed. I then pressed the lever to dispense ice. I hear a humm like power is getting to the motor but the motor is not turning. I hear a click like the selonid is engaging. I'm having to assume at this point it's the motor and I am going to go ahead and order a motor. I've found a motor for the unit at partselect.com for $65.54. Hope this helps you.
Apr 21, 2009 | GE GSS25JFM Side by Side Refrigerator
Icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Nov 21, 2008 | GE GSS25LGM Side by Side Refrigerator
GE side by side not dispensing ice out front
could be frozen auger motor, try turning motor by hand.
May 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
487 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
