Question about Kenmore HE2 Plus Front Load Washer
What does PF mean? on the electronic display - Kenmore HE2 Plus Front Load Washer
    President:
  • 1,776 Answers
The code PF indicates that a power failure occurred while the dryer was running. Press pause/cancel to clear the display. Hope this helped and best wishes.
Posted on Jul 26, 2009
PF code
Depending on manufacturer and model, PF can mean a number of things. On my stove, PF simply indicates "Power Fail" Yours may, too. You can clear this generally by updating the clock display. To verify that PF does indeed mean power fail for your stove, simply shut off the power for the cicuit than supplies the stove. This can be either circuit breaker or fuses. Turn the power back on after 5 or more seconds and if it displays PF again, you know it means power fail.
Otherwise, please provide the manufacturer and model of you stove for an answer.
Jul 02, 2012 | Ovens
My electrical panel only shawing PF and nothing hapen when I press Start
Hello & Welcome to FixYa
PF error means power failure and is displayed when the electronic control is bad. You can take it apart and blow compressed air on the control, if the problem returns then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Whirlpool Gold GW399LXU Gas Range
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Error message PF on my dryer when i try to start it
Hello
PF error code means power failure and is displayed when the unit is either not getting power or the control board itself has gone bad. Please check if the unit is getting enough power and then leave the unit unplugged for 20 minutes. If the problem returns then replacing the electronic control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 24, 2010 | Frigidaire Dryers
I HAVE THE PF CODE FLASHING ALONG WITH THE HIGH LOW OFF LIGHTS AND PRESSING BUTTONS DOESNT WORK
Hello
PF error code means Power Failure, it is displayed when the unit is either not getting enough power or the power board also known as the electronic control board has gone bad and needs replacement. As pressing buttons doesn't work then first unplug the unit for 15 minutes and then check, if this does not help then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 20, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Whirlpool Duet sport dryer that came with the house I bought a year ago so I have no manual. What does it mean when the display says PF? Clothes were dry but display waid PF
The only PF I am aware of means power failure. Try unplugging the unit for awhile then try it again. This may reset the computer.
Feb 14, 2010 | Whirlpool Dryers
GE JBP45G oven display module keeps on showing ''PF'', whether I turn oven on or off.Have to constantly reset clock to make the ''PF'' message dissapear. My broiler element is not working,but why is ''PF''...
I can easily explain the "PF". It means your EOC or electronic oven control/timer is losing power for some reason, hence the "PF", for power failure.
I`d suspect the control itself is defective or at fault as they have built in transformer`s that can become faulty.
I would first insure your power supply cord is secure and in good condition in the wall or you don`t have loose wires going to the timer.
Hope that help`s move you forward, let me know if I can assist you further.
Good luck.
macmarkus :)
Feb 10, 2010 | GE Ovens
Pf??
PF means power failure.
For short outages the clock may still have correct time
(there is a battery backup for that), but the PF will
be displayed. Setting the clock will clear the PF
indication.
Press 'clock set-start' button, (under clock display)
enter time with numeric keypad,
press 'start' button. (to right of clock)
Jan 03, 2009 | KitchenAid KESC308LSS Electric Kitchen...
WHIRLPOOL SLIDE-IN RANGE
PF means power failure.  Usually you can hit cancel or clear and this will go away.  Let me know if this helps.
Oct 12, 2007 | Whirlpool RF378 Electric Kitchen Range
Kenmore HE2 Plus Front Load Washer Logo
230 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
