Question about Plumbing
Brasscraft cutoff valve breaking into two pieces all by itself. i have had three do this in last 4 months. i am a home builder and this problem has occured it 2 different houses. causing serious water damage to both. is there some sort of recall?
  • 117 Answers
Get some different valves! they are way touchy if the valves are over tightened it will split them and if they are under tightened they will pop off. try putting some pipe dope on the treads if they are compression ones that helps even out the tightening and gets them nice and snug
Posted on Jul 29, 2009
Toilet tank leaking
Hello David McInnis,
There are Three basic opportunities for leaks from the classic TOILET TANK DESIGN (separate BASE & top-tank)... around the FLAPPER VALVE alone... Typically the flapper valve & two hold-down screws. These CANNOT be repaired without removing the entire tank. GREAT CARE should be used to not FRACTURE
the mated surfaces by OVER-TIGHTENING.
This is a great time to FRESHEN UP all the
Perishable gaskets & seals... and while I NEVER advocate using any ABRASIVES on gloss finishes... Pumas stone seems to be the FINAL TOUCH in a total renewal
(to REMOVE the built up (very unsightly
TOILET BOWL RING...
Amazon com toilet bowl pumice stone
ADDITIONAL PARTS:
- Water fitting to FILL VALVE (compression fitting).
- FILL VALVE through tank (gaskets)
- Flapper Valve base, gaskets & bowl interface ring
TO Make sure all the surfaces are clean an firmly
positioned and it is not LEAKING anywhere... place
clean dry paper on the floor behind the bowl
(under the tank).
EACH/EVERY drop will leave a mark...
Do NOT over-tighten any fittings!!!
If the WALL VALVE is less than NIMBLE... also a great opportunity to UPGRADE TO A QUARTER TURN
BALL VALVE... A little shopping will find you EXACT VALVE CONFIGURATION...
Hope this helps.
LASCO 04 3809 Toilet Tank To Bowl Bolt Kit Brass Bolts with Washers Hex...
Fluidmaster 6106 2 3 4 Inch Tank to Bowl with Three Bolts and Gasket...
BrassCraft G2CR19X C1 1 2 in NOM Comp Inlet 3 8 in OD Compression Outlet...
Kohler 1068031 Fill Valve Flush Valves Amazon com
Apr 02, 2017 | Plumbing
Heat does not work shuts off after ten secounds
ClassicFlame 36EB220-GRT 36" Traditional Built-in Electric ...
www.amazon.com/ClassicFlame...GRT...Electric-Firep...
Amazon.com, Inc.Save Big On Open-Box & Preowned: Buy "ClassicFlame 36EB220-GRT 36" ... TheClassicFlame PRO 36" traditional built-in electric fireplace insert, 240 volt, ... Heatingyour entire home all day may not be the best economic choice for your utility ... Youcan shut off the heated air blown to different sections (or 'zones') of your ...
Amazon.com - ClassicFlame 36EB221-GRC 36 ...
www.amazon.com/ClassicFlame...Electric-Fireplace/.../...
Amazon.com, Inc.
Rating: 4.1 - ‎7 reviews
36\" Builder's Box Electric Fireplace Insert The ClassicFlame builder's box features... You can shut off the heated air blown to different sections (or 'zones') of your home... 36EB221-GRC 36 inch contemporary built-in electric fireplace insert will .... Wedid finally get the pieces after about a month, and the unit is working now, ...
ClassicFlame 36-Inch 120V Traditional Builders Box ...
Jan 18, 2016 | Classic Flame PRO 36EB110-GRT 36 Inch...
I've now replaced my dryer valve coils for the third time in 4 months. So something is causing them to break down. The problem is the same each time... the coil with three prongs loses continuity. Any
I hate to say it, I only had this happen 1 time in 25 years I been doing repairs. It would have to be the Valve the coils are mounted too. I'm not 100% on this but the 1 time I had it happen to me it went bad 3 times in a month, I spoke to maytag tech hotline and they suggested it, and it took care of the problem for me.
Sep 11, 2014 | Maytag Dryers
Dont know how to assemble brasscraft auger with T handle
www.brasscraft.com
www.brasscraft.com/products.aspx?id=730
Apr 11, 2014 | Brasscraft 1/2 in. x 50 ft. Drain Auger...
How to assemble
Without a model number, I'm going to guess that you have the standard model that ISN'T drill driven it has an actual motor. There aren't many parts and it should've come in one piece from Home Depot of where ever you purchased it. The three main pieces are the drum, cable, motor and frame. To remove/install the drum, pull out the lever on the back lower part of the frame and pull the drum off the shaft. The motor is held on by four bolts that attach it to the motor mount. If you need to install a cable on this machine, push the cable in through the cable guide and attach it to the mount on the inside of the drum. As you face the drum the cable will wind counter clockwise.
My drop saw runs at 5000 rpm .most 14" discs are only rated to 4400 rpm. Are there 14"discs rated at over 5000rpms
go 2 home depot and buy Norton brand blades a lot of blade suppliers are putting a pic of cutoff saw on the blade itself 2 tell u its 5400 rated home depot and Norton r the cheapest and lasting
Jun 29, 2010 | RTO 20 14" Abrasive Chop Saw Blades Metal...
Heater control valve leaking 03 ford ranger
let me assume you have a 4 port heater control valve (4 water ports and 1 vacuum line). I have fixed several and they only leak for a short time before the valve completely breaks and you lose all coolant immediately. (not good) The leak is caused by the elbow piece that threads into the control valve. The threads just deteriorate and come apart. this repair is very easy and can be done yourself for under $30 dollars by going to your local auto store and purchasing a new one. Im also going to assume its not a hose you were specific about the valve. I guess if you were in an emergency and needed a quick repair that may or may not work long you could always epoxy or cement the defective piece together but this wouldn't be recommended except in the case that it is (a) not your car and; you dont like the owner:-). I hope this helps
Lucas
Dec 12, 2008 | 2003 Ford Ranger Regular Cab
Plumbing Logo
208 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
