I have model LTV-32w4 HDC and the picture starts out nice and clear and after being on for 30 minutes the picture becomes progreesively dark and darker.
  • 3,037 Answers
Sounds like a failing backlight or the backlight inverter. You can confirm this by shining a powerful flashlight on the screen and you should be able to see a picture when it is turned on. If this tv is under warranty, then send it in or do what the manufacturer wishes. Otherwise, you can attempt to replace the parts yourself, after testing whether the voltage from the inverter is dropping and causing the bulb to dim, you can then know whether you should first replace the bulb or the inverter. You can get new parts through a local shop, through the manufacturer, or from online suppliers. The backlight will be located right next to the screen panel inside the unit. If you don't feel comfortabling doing this, then have someone that is or take it to a shop. Let me know how this turns out.
Benjamin
Posted on Jul 26, 2009
Our TV/DVD player (LTV-32w4 HDC) is just out of the 4 year extended warranty we bought. The TV works fine, but the DVD player will not start up. When a disc is inserted, it seems to be trying to start...
Hello
According to your complaint post, the fult is due to its DVD mechanism itself. It will be best to replace the DVD tray mechanism [ plastic made one]. You can bought it from most of the electronic spare part shops at your town. But the model fitted with Westinghouse will be very difficult to get. Anyway try to get it. The fault is with loading tray mechanism itself. OK.
Aug 23, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LTV-32w4 HDC widescreen DVD Combo
Hi Mouse999. From reading a bit, it seems that there's no region free hacks for the built in dvd player in that specific model. A solution for you, would be to purchase a standalone dvd player, one that is region free or one that has a region free hack available, and to connect it to that tv. If you're in europe and your tv is pal, you also need to have a dvd player that will read both Pal and NTSC video dvd's ! If that doesn't help, please be more specific, i'll be glad to help. Thanks, cheebster.
Jul 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My Westinghouse LTV-32w4 HDC has went green. Sound is perfect, but the screen is solid green. Doesn't matter whether it's the cable box or the internal DVD. It's solid green.
The Tuner signal board is dead.The Tuner signal board,that the board,where the incomming broadcasting signal plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 17, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
How to remove dvd drive for Westinghouse LTV-32w4 HDC 32.02 in. HDTV LCD TV/DVD Combo
http://www.retrevo.com/support/Westinghouse-LTV-32w4-HDC-TVs-manual/id/278ci973/t/2/
First you would have to get a service manual, this shows you all you need to know about the unit. Without it, it is very difficult to even remove the case. but once inside, it is basically a simple task, to find the drive, remove the fastenings, and the Cable, obtain an EXACT replacement HDD, and reverse the procedure, it may pay to format the HDD first, FAT32, I believe, although your manual will be more specific.
Jun 18, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Screen goes dark after a few minutes of tv on
It has bad lcd inverter and Westinghouse don't sell the parts either.
Mar 23, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LTV-32w4 HDC No signal how do i rest the signal
Hello, this all depends on what input signal you are trying to see, there is differnt ways to reset the signal, I would love to help you resolve this issue personally, please email me at westytech@wde.com so I can better assist you. Also if my assistance is helpful please rate my help on this website.
Nov 05, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
TV appears dead
the mainboard is damaged and need to be replaced
Jul 09, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Dec 22, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
