A few weeks ago, we noticed our dehumidifier would not start or run at all. Water pail not full (it's empty), won't start no matter what the humidity level, the red light does not turn on. No sound, no fan, no compressor sounds. We have switched the device from outlet to outlet (and to it's own circuit) and cannot get it to work.
It is in a finished playroom in essentially the lower level (basement?) of an embankment ranch (split level). It is cool down there but certainly not cold.
I either need to find a way to understand/resolve this or buy a new dehumidifier - this one is under 3 years old (maybe more like 2 or 2 1/2 years old). It's getting too cool and moist down there.
I'm reluctant to go and buy a similar model but am unimpressed with other options I've seen on line.
My 54351 dehumidifier only collects about 1/2 cup of water in a 10 hour period, but after I turn it...
(More)
My 54351 dehumidifier only collects about 1/2 cup of water in a 10 hour period, but after I turn it off for several hours, I later find over a quart of water in the collection bin. The unit is only 6 months old. Should I take it back to Sears?
My kenmore dehumifier model 580 (35 pint) cycles on and off and will not stay on for an extended...
(More)
My kenmore dehumifier model 580 (35 pint) cycles on and off and will not stay on for an extended period.
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running....
(More)
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running. Kenmore model 580.54351 35 pint Basement is wet and not sure if this model is for basement temps but it works the same in warmer temps.
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change...
(More)
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change the %. It just beeps. the bucket full light flashes even though the bucket is empty. I usually set it on 3 hrs on/off. Have tried powering on/off, etc. Coils not iced up.
