Peggy Nehr Pence Posted on Jun 23, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Marantz SR 5100 comes on but has no sound. What do I need to check on it to possibly get it to work?
richie46
Level 3:
Top Expert:
  • Marantz Master 12,962 Answers
  • Posted on Jun 24, 2017
richie46
Marantz Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941598
Points
58151
Check to see if the preamp section is working so as to isolate the source of the anomaly.
Is the Marantz SR68 an FM tuner please?
No, it is a Surround Sound Receiver for taking television signal, or a signal from another device and amplifying it to multiple speakers..
https://www.google.com/search?q=Marantz+SR+68
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Marantz sr 5001 turns on but no sound
Answer lies on page 48 of your
Marantz SR 5001 Manual
If problem is not resolved, it may needs servicing.
2answers
Marantz sr 4000 powers up, but no sound
Try plugging in headphones, if they work, it sounds like outputs have blown,
1helpful
What would work better for Marantz SR 4200 Apple Composite or component cable? In order to play music through the amp as well as watching videos
Component Video is a big step up the food chain in quality. Component Video inputs are for video only, not for audio. I don't see Component Video inputs on the Marantz SR-4200; only Composite and S-Video. S-video would be a step up from Composite and it carries analog stereo sound.
You don't give any clues as to the source's audio capabilities.
Digital Audio of either flavor is preferable. Grab the best possible TV-related audio from your Cable/Satellite box to the Marantz and run a pair of RCA audio cables to your TV just in case you want to watch the weather channel without hi-fi sound.
1helpful
Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
Marantz SR-940
Just finish repairing Marantz SR 940 with no sound output. Problem was a clamped speakers relay located behind the speakers lugs (red and black post connectors). To reach the relays you must remove the little circuit board behind those colored connectors et unsolder the posts. There is 2 relays, one for A set and one for B set of speakers. Very EASY when you know the solution!!
4helpful
4answers
Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
