How do you replalce the switch,lid - Washing Machines
  • 5,911 Answers
If this is a Kenmore, Estate, Roper, or any other Whirlpool manufactured top loading washing machine, the following link explains step-by-step how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
PS If you have any other brand washer please post back with your model number so that I can verify how it is configured.
Posted on Jul 26, 2009
Panasonic cupc24dkq
try to fix it. However if are serious damage. The only solution is to replalce, You can go to Radio Schack. or another store parts electronics. You can do it by search in the web internet.
God bless you
May 31, 2013 | Televison & Video
Lifegear motion plus 97920 problem
please adjust the REED switch and see the diagram attached. Test for open or faulty. Clean it + tight the connector very well.
2) if you equipment has battery replalce by new ones and clean it, and putt with FULL energy.
3) TIGHT THE RIBBON CABLE for keypads , clean it and try again.
God bless you
Feb 22, 2013 | Exercise & Fitness
Weslo cadence g40 stops for no reason
you must LUBE THE deck belt by aprox 150 miles. In according with the schedule maintenance,
Please LUBE the deck belt+rollers bearing.
see the video
If the problem persist time to replalce the OLD board deck belt.
God bless you
Jan 22, 2013 | Weslo Cadence G40 Treadmill
Clicking noise in base of a proform 735 CS making it unuseable
see the video and proceed according. This happen because the treadmills you must lube 150 miles aprox. lube the rollers bearing.
If the problem persist, Time to replalce the old board by new ones.s
God
Jan 21, 2013 | Exercise & Fitness
My Kenmore dishwasher is making a grinding noise during the wash cycle
see this causes:
Water-inlet valve
test the inlet valve for defective and replace
Motor
bearing worn replace
Heater fan
bearing worn, replalce
Pump open the pump and take out the sediment, or debris inside, or replace.
Jun 18, 2012 | Kenmore Dishwashers
How to replalce the belt
your instruction book shows you how to change this belt it should be easy just check the top and see if you lock tabs to remove the cover
Mar 03, 2010 | Kenmore 34723 Grab-N-Go Upright Vacuum
I have an HP flatbed scanner 5590 - "lamp error"
I had the same problem and I finally unplugged for a few days
and when I replugged it worked !?
Nov 30, 2008 | HP Scanjet 5590 Flatbed Scanner
Blown fuse
Check your owner's manual. There will be a diagram of your fusebox telling you which fuse is the one you need to replace.
Aug 09, 2008 | 2002 Saturn VUE
Question about whirlpool catalyst 27" washer
F3 means lid switch failure. Heres what the service manual for your washer says about the failure.
Flashes if the lid is NOT opened after the cycle was completed. The
electronic control board must detect that PAUSE/CANCEL was
pressed during a cycle or the lid was opened at least once at the end
of any cycle. This is continually tested to ensure proper lid switch
operation. If “F 3” is flashing, check continuity of the lid switch.
• With the lid closed, lid switch contacts should be closed.
• With the lid open, lid switch contacts should be open.
• If the lid switch has failed, replace it.
• If the lid switch is good, replace the electronic control board.
Apr 05, 2008 | Washing Machines
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
