Question about Clairion Convection Heater - HC-1500
The fan and the heater do now work !
Good evening, I put my Clarion to work and it worked fine for about half and hour at 22Celcius.
Then there was a short in my main electrical panel. A fuse shorted out.
I changed the fuse from the electrical panel and when I started he Clarion, the only thing that you see are all the lights from the panel but there is nothing working. What could be the problem ?
Thank you
  • 625 Answers
Check for a tripped overload. reset or replace it.
Posted on Dec 07, 2007
My fan for my heat was working fine i got home from work shut off the car. my husband went out a half hour later to pick up kids and it would not work. we checked the fuses all are good what else could it...
This is going to be the fan itself or the control dial for the fan. You can check this a couple different ways. One is to remove the fan and put a 12 volt source on it to verify the fan is still good. The other way is to take out the controls and short the wires. If this works then it is the control itself or a loose connection.
Feb 28, 2015 | Cars & Trucks
No immediate heat
Check the fluid level in your radiator reservoir. Mine was doing the same thing and I found mine was very low. Filled it up and the heat came on through.
Dec 28, 2012 | 2005 Nissan Frontier
I have a Vornado TVH600. The heating coil does not heat up; the fan is working. The heater has only been used for a couple of hours--worked fine and then one day simply stopped heating.
Sounds like you got a lemon. Contact Vornado Customer Service - the TVH600 comes with a 5 year warranty that covers all costs associated with replacing or repairing the heater. They even pay for shipping costs as long as the unit is still under warranty. Just give the rep the serial number on the bottom of your product. The number is 1-800-234-0604. When you call, you'll actually get a real person, and the support team is very pleasant and helpful. Good luck with your heater!
Dec 10, 2010 | Vornado TVH600 Electric Heater
My cooling fan does't come on ,even if the ac is running. Bob
well so long as the engine dont over heat whats the problem?
some cars the fan only ever works after its been running for about half an hour and only then for about 30 seconds,,,
just keep a close eye on the heater gauge if it stayes in the normal its doing just fine, dont worry about it,how long have you had this car? has it ever boiled up on you???? dont fix it when its not broken
Oct 24, 2009 | 1999 Saturn SL
I have a GE side by side.. When we got home last night I noticed some water on the the floor and the power was on inside the refrigerator but the cooling apparently stopped working. I moved the fridge and...
The defrost timer will turn off the compressor and its cooling fan. At the same time it turns on the defrost heater, and usually leaves the freezer fan running. Defrost can take half an hour, easy. As soon as the defrost thermostat is satisfied, the defrost heater is supposed to turn off, and the compressor may come back on. The defrost timer is about the size of a cell phone, with about five wires going to it in a plug. It has a small dial on it that only goes one way. You can mark it and wait a half hour to see if it moves.
Apr 14, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My Pentax A30 will not stay switched on
Try drying the camera out - mine did this after it got wet. After a few days it still didn't work so I put it in front of a fan heater [not too close] for half an hour and after that it was fine.
Feb 12, 2009 | Pentax Optio A30 Digital Camera
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
Heater fan only works intermittently, Usual faulty when raining.
mine was the same 1999 a4 1.8se avant, i replaced the fan from gsf car parts £46 take out the glove box, and its there it unscrews and 1 plug then its out i had never done one before and it took me an hour and a half, when its intermitant like that its on its way out, mine works fine now, you could also just replace the pollen filter which sits on top of it first if you want but would recomend replace fan aswell , regards jim
Oct 20, 2008 | 1999 Audi A4
97 Ford Taurus
Replace the engine thermostat, it is probably stuck open.
It is located where the top radiator hose enters the engine block and is supposed to close when the engine is cold, thus prevent coolant from going to the radiator while the engine is heating up.
At engine operating temperature, it opens up, sends the coolant to the rad, and keeps the engine coolant at that constant temperature.
99% of the time, this is the culprit.
The other 1% could be a clogged/partially clogged heater core, or a busted heater core (accompanied by a coolant leak/loss over time) which fogs up the windows even more when the heater is on defrost.
Thermostat replacement is an easy, quick job and cheap.
Heater core replacement is a little bit more time/money consuming
Aug 27, 2008 | 2006 Ford Taurus
Really Loud Fan Noise
They have a bad issue with that. The fans fail all the time inm those clarions... I can sell you a used fan for $40 or if youd like me to repair your unit you could send it to me and i will repair it for a total of $200. ampman out!
Dec 13, 2006 | Clarion VRX755VD Car DVD Player
Clairion Convection Heater - HC-1500 Logo
246 people viewed this question
Top Clairion Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Clairion Heating and Cooling Expert? Answer questions, earn points and help others
