Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Laminate floor steamer, cleaner
What is the best laminate floor steamer, clean and dries. I currently have the Haan and I can use it on my tile, but not on my laminate. It stays wet and leaves marks.
reddevil6
  • 1673 Answers
SOURCE: bissell laminate floor cleaner wet vac and flips to dry vac
You just need to replace the cap and valve part # 2036919, You should be able to order the part thru Bissell.com, or they will tell you who you can call close to you.
Posted on Feb 05, 2008
SOURCE: H300 brushes won't stop spinning
I have found that the plastic piece on mine is wore out and slips when the trigger is pulled back. If you look underneath the dirty tank, you will see the black plastic pieces that over lap. I took a wiretie/zip strip and placed it around the spot where the pieces join and made sure it was real tight. This seemed to fix my problem (until the wire tie starts to wear out and stretch at least)
Posted on Jul 09, 2008
provactek
  • 17 Answers
SOURCE: Soap/water solution pouring out on floor when trying to use hose & attachments
The attachment hose is torn right where it connects to the motor . And there should be a trigger on the end of the hose right below where it connects to the hand tool.
Posted on Oct 02, 2008
SOURCE: Shark Floor Cleaner streaking on pergo laminate floor
Start with a clean pad. A dirty pad wil spread the wet residue around and strek the pergo. After steaming use a clean microfiber dust mop to buff the pergo. It will dry and shine yur laminate.
Posted on Jan 14, 2009
  • 31 Answers
SOURCE: it leaves dirt and fluff in the rollers not in the
is there something stuck in the air passage between the tank and inlet
Posted on Jan 07, 2010
How do i get ceramic tiles to have a shine again. they are not high gloss but they used to have a shine to them
You might try a steam cleaner like the Shark Steam Cleaner. If you use a polish, sometimes that makes it worse and makes your tile dull. Just use plain old soap and water. The Shark also scrubs your floors as it cleans.
Feb 13, 2015 | Vacuums
I have a dc56, will the new tangle free turbine tool, part No 925068, fit it?
Hi Lyn, it's Jack at Dyson.
DC56, the new Dyson Hard vacuum cleaner, is engineered for quick cleanups on hard floor surfaces - wood, laminate, lino, tile etc. It also converts into a powerful handheld vacuum for dusting tasks around the home and inside the car.
The Dyson Hard is not designed for use on carpeted floors, and we do not manufacture a motorised head for this machine as it lacks the wiring and connections needed to supply current to a motorised head.
Airflow-driven Turbine heads, such as the Tangle-free Turbine tool, are engineered to work with the performance characteristics of our mains-powered vacuum cleaners, and are not compatible with Dyson cordless or handheld vacuums.
However, we do have a range of accessories which are compatible with DC56, and you can find these on our website: http://www.dyson.co.uk/accessories/variant-accessories.aspx?pid=DC56-dyson-hard
Apr 02, 2014 | Dyson DC56 Hard Floor Wet/Dry Bagless...
Best way to clean a laminate "wood" floor. I use Pine Sol and lately have been noticing streak marks and dullness.
The old standby of glass cleaner should do the trick. Use a spray bottle, and spray a small 4x4 section at a time, let it sit for about 2min. , then wipe up with rags. Do NOT let it dry on the floor. You have a buildup of product on the floor. The pine cleaner has a small amount of oil in it and it builds up over time. For a good glass cleaner- I would suggest ZEP glass cleaner. For daily cleaning- I would suggest white vinegar 1 part vinegar to 3 parts HOT water. It will sanitize, and also remove salt stains from the floor left by winter boots and dog footprints.
May 19, 2017 | Vacuums
How do I remove a hardwood floor polish safely from a laminate floor
www.hard-wood-floor-cleaners.com
and select the best chemicals and use for your hardwood polish laminate flooring.
God bless you
Aug 02, 2012 | Vacuums
I HAVE A BISSELL PROHEAT CARPET CLEANER AND WAS WONDERING IF THERE IS AN ATTACHMENT TO CLEAN TILE FLOORS. THANK YOU BONNIE UPDYKE
you should check the website of the manufacturer, be carefull as the grout between the tiles is the weakest link to keeping your floors solid...you may damage or fade the color of u'r grout if it is not protected...and if it is protected and has been sealed with a protectant, then you may be removing the sealant with the extreme hot steam from the carpet cleaner.
Feb 22, 2010 | Bissell 7950 ProHeat Upright Wet/Dry...
I need a cleaner for my tile floors which model is best for tile? I am 79 years young and I need something that I can handle. There are so many models that I am confused as to which one to buy.
1st what type of tile do you have? many people use the word tile genericaly...ie: porecline tile?, ceramic tile, natural stone (which is porous), in general ceramic and porceline tiles do not need any protective finish maintenance with chemicals, that said ...no accumulation of foreign wax buildup and dirt should be present...so a mild mixture with white vinegar and cold water will clean your tiles very niceley and also is a bacteria sanitizer ( if you have food spills and any pets in the house). A good self squeeze sponge mop and pail is all you really need.....save your money and do not be fooled or swayed by such nonsense ...also once the floors have been washed and dried...you can then apply a good quality grout sealer with a hand sponge, and let it dry for 3 hours and then apply a 2nd coat overnight. This will help to keep any colorful penetrating fluids from affecting the color of your grout.
Sep 29, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
324 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
