You may not really have a focus problem... To fix it, all you have to do is remove all the screws on the bottom of the screen from the front of the tv. Generally what happens is that the lens on the 3 guns, RGB get dust and crud accumulation on them. All you have to do is get a soft cloth, like a microfiber one to clean it off. I would recommend that you use a mild cleaner and water to clean it. Also the mirror is another thing that you'll need to clean. It too gets dirty, On the lens and the mirror it looks like a white or grayish film that is clouding your picture.
Not good for a non qualified service personnel!
WARNING! focus is close to the HIGH VOLTAGE!
Consider this.... if your TV is more than 5 years old, it maybe the crt is gone?
Those TV has self focus... nothing to adjust what so ever?
Try cleaning the inner lens... might help?
Fixya won't let me answer in Spanish, I tried. There are 2 fuses for the reverse light. 1 under the hood in the fuse block, and 1 under the rear passenger seat. Check both of these fuses. Use a volt meter and see if you're getting power to light sockets and fuses to narrow it down for you. buenos suerte
hola, si el foco esta bien, hay dos posibles fallas, una es el triac que controla el foco que esta en la tarjeta electronica ( tendria que revisarlo un tecnico por si hay que reemplazarlo) y la otra es que el control remoto este sucio, (sera necesario abrirlo y limpiarlo con alcohol).
Hi there it is ink error. You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Start with printer off
Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
While holding the Power button, release the Resume Button.
Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
By wrapping a flat blade screwdriver witha towel and gently prying upward I removed the nobs. Now on to the next challenge. Thank you for allowing me to post. The project is not finished. May need other help.
