SOURCE: sending wireless messages
If Norton is intervening, it's most likely to be the anti-spam package that's doing it - make sure you don't have it installed, and if you do, try disabling it, if that doesn't work, try uninstalling it. That should do the job.
SOURCE: deleted yahoo mail folder, sent items, & drafts
one of the important yahoo folder that i have was deleted, my draft folders went empty, my sent items,,, some of important sent items that i have are all gone,,,, how can this be possible???
SOURCE: Having problem with syncing E-mails between folders on Blackberry
Your Work emails should Sync wirelessly as they are pushed through a BES server. Concentrate on fixing this and it should fix the others.
Do you move any emails when it arrives in your inbox? or do you have any auto-rules setup which moves them automatically?
If all else fails; Backup your device using Desktop Manager. Wipe the device and Enterprise Activate from fresh. Once setup then restore the data from Desktop Manager.
I hope this helps, please do rate my solution.
Thanks,
SOURCE: how do i view my email "sent" folder on blackberry
You will not be able to view e-mails in other folders. This is a BES 5.0 feature. Most companies are not there just yet. you can have it show your sent items from the option menu within the Inbox.
SOURCE: Outlook 2003 email junk folder
the Exchange Server must have blocked the center. To unblock it, the system adminsitrator has to unblock the center from the block list
