I need to chage the power cable from a 3 prong plug to a 4 prong plug. I dont have the manuel for the Kemore Eltie HE5... so i was looking for the electrical schematic to see which are power cables and which are ground lines, and what order to place the red, black, green and white cables
  • 520 Answers
If you follow the existing wire to the rear of the unit where it hooks in, there should be a removable cover with only one or two screws holding it in place. Go ahead and take this off. It should have a picture inside on this cover but they are sometimes hard to read and understand. So here's the most basic way to hook it up. If you look directly in there will be a plastic piece with three slots for wires to go, called a wiring lug. Down below it, connected to the middle slot there will be a copper/metal strap connected to the ground. You need to remove this strap and discard it, it will not be reused. Be sure to save the screws to the strap because those will be reused. Connect the black wire from your plug to the far left lug, the white wire to the center lug, the red wire to the far right lug, and the green/ground wire will connect to the unit body with the screw that was taken from the lower portion of the metal strap earlier. To further explain what wire does what this is standard on any US household 240 volt wiring. Black and red are hot wires that carry 120 volts each. The white wire is a neutral wire to relieve excess voltage back to your breaker panel. The green wire is the ground on plug in situations but in hard wire or internal house wiring situations the ground wire will just be a bare copper wire. Hope this helps gets your machine going for you. Please re post with updates or questions. If you feel that the solution I've posted has helped then please accept and rate.
Thanks, cj2176
Posted on Jul 26, 2009
Need to wire a t30 242-5N with a 4 prong dryer cord help
on 4 prong,2 are hot 1 is common,1 is ground,,on 3 prong 2 are hot,1 is common ,you dont need ground,build your own plug
Wire Dryer Outlet
Sep 24, 2014 | Dryers
Manuals free
Your question was worded poorly and it's difficult to understand what you are asking. As a guess, if you are looking for a 30-amp adaptor cord set, perhpas this will work:
Conntek 20601 25 Foot 10 4 30 Amp 125 250 Volt 4 Prong L14 30 Transfer...
If it's a 3-prong adaptor:
Camco 55333 30 AMP 3 Prong Generator Adapter
Or a 15 to 20 adaptor:
Coleman Cable 09020 12 3 9 Inch Generator Cord Adapter 5 15P to L5 20R
Aug 27, 2014 | Electrical Supplies
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
Don't know how to switch from 4-prong to 3-prong power supply
Your new 3 prong power cord needs to be wired up just like the 4 prong you just dont have the seperate ground . in the use of a three wire cord ground runs thru neutral .Hook black to black on the terminal block on unit. hook red to red on the other side of block and white to white or green in the middle reinstall the cover ....Plug in and your ready to dry
Aug 14, 2010 | LG DLE2532W Electric Dryer
I have a 4 prong dryer but the plug in the wall is a three prong, ibought a four prong plug and i dont know how to connect a three wire into a four prong plug please help me.. hugo
Do NOT try and change the receptacle please. It is dangerous and we do not want anyone getting hurt. In your case, it would be better to put a 3 prong cord on the dryer. Overall you could call an electrician to install the 4 prong receptacle, which will require new 4 conductor wire as well and run to the breaker box. Get a flat style 3 prong dryer cord and we'll tell you how to install it. Unless you call an electrician. ;-) If this helps you, please rate my answer. Thank you.
Jan 07, 2010 | GE Dryers
I have a 4 prong pigtail
Here is what I believe you have.
The 3 prong plug on your dryer is configured with 2 lines of power and 1 ground. The 4 prong receptical is 2 lines of power, 1 neutral, and 1 ground.
You will have to turn off the breaker to see how the receptical is wired by pulling it out and looking at it. You can then buy a 4 prong plug to match it and only wire up the 3 prongs you need for your dryer and leave the 4th prong empty.
Good Luck and hope this helps
Apr 18, 2009 | Speed Queen AES28AWF Electric Dryer
I cant figure out what the printer power cable is for my Dell 924
If you are talking about the cable that plugs into the wall socket, it shoudh have a 3 prong plug that goes to a square block that fits into your printer.
Jan 08, 2009 | Dell 924 All-in-One InkJet Printer
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
