Clogged drain in front load LG Washer. Cleaned filter and the drain hose in bottom is not draining any water. Clogged up
  • 42 Answers
Hi
To completely clear any clogs in the washing machine drain, use a pipe auger (snake) through the drain hose and look out for any debris/cloth that might be clogging the hose.
Remove the drain hose from the back of the washing machine. This is normally held in place by a clamp or a couple of screws.
look for any clogging from the orifice which opens up for the drain.
if this doesn't solve the problem, you have to open the machine to look for blockage in the drums, which is better handled by a serviceman.
cheers
Posted on Jul 26, 2009
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Posted on Sep 18, 2010
Fowl odor in front loader
Clean out the small holes in the gray door gasket (at the bottom) to allow water to drain back into tub. Open access door at bottom left on front of machine, use small hose to drain remaining water from machine, remove and clean out filter there. Re-install. Run washer on the tub clean cycle if you have that cycle, or if not, use the longest, hottest cycle you can, but make sure to use a commercial washer cleaner like Affresh, Washer Magic, Whirlaway hot tub cleaner, etc., with no clothes in the washer. After cleaning tub, make sure you only use one tablespoon of HE detergent per cycle, and only one teaspoon of fabric softener per cycle if you use softener.
Feb 13, 2011 | LG WM-2277HW Front Load Washer
The water will not drain automatically we must use the outlet on the lower left bottome to drain manually...the error code we see on the device is "OE" what can we do to fix this?
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a millimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please revert for any further assistance.
Daniel
Feb 11, 2011 | LG WM-1832C Front Load Washer
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Daniel
Jan 10, 2011 | LG WM3431H Washer and Dryer
Our LG Tromm WM1814CW frontload washer is not draining in the spin cycle, but its only sometimes. We have tried cleaning the Filter and its clear, we looked in where the filter is to see if its clogged,...
hi Shellinator7.
check the small drain hose on the side of the pump that is clogged, then that is not a failure that will significantly affect the normal operation of the washer. If your washer is not draining okay and you don't mind catching some water that spills out of that pump filter area when you open it up, then you don't necessarily need to remove that front panel and bother with unclogging that small drain hose. If the large hose between the tub and the pump or the discharge hose between the pump and the house drain behind the washer is clogged, then you may need to open up that cabinet.
you could also check out this link and read up some more on this.
LG Tromm front load washer not draining in the spin cycle Google Search
Dec 14, 2017 | LG WM1814CW Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
I have an LG2455h front load washer. It will not drain. I have cleaned filter and checked drain hose for clog. Could the pump be clogged, and if so how do I get to it.
There should be 3 screws at the very bottom of the bottom panel, Remove panel there should be a canister shaped screw top. You can unscrew that. That is your filter before the water pump. Make sure you have some towels ready. Good luck!
Aug 21, 2010 | LG WM2455 Front Load Washer
LG WM2233H* Clogged drain
After draining and cleaning filter, reset washer--Unplug unit and hold Start (selector) button for 10 seconds. Plug unit in and restart.
Oct 28, 2008 | LG WM2277H Front Load Washer
Washing Machines Logo
438 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
