SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
SOURCE: Error code 1 2
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
SOURCE: cyberpower 525L, power light blinking, beeping.
525L series as very matter that cause to emliminte the problem try this matters lst.
step1 the power is 300watts -/+ any power supply that above the usage will be overload maybe thats the problem when your cpu & does't power. what are the devices that u plug it to the ups? it important what the devices u plug in maybe using high watts for eg printer, scanner and fax mechines. the solution unplug out those not important device and plug your cpu to test and see it work? and also the socket you plug it in from th cpu, try to plug one of the device to test and see if the power socket is working.
step2 or could be the battery problem juz change the battery and test it up. here are the below website what are the spec of the battery.
http://www.batteries.com/index.asp?N=4294960483+4294958897+4294957694&Ne=25&Nu=p%5Fprodcode
step3: if all this step 1 and 2 does't work it could be the socket from the ups is faulty, ask for the vedor to check your ups if it need?
SOURCE: Green light then a red blinking light and no picture when we turn
If set works ok after some attempts the probable cause wil be some bad caps in the power supply.
SOURCE: flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
