Question about Dell Dimension 3000 PC Desktop
Unable to startup in Windows XP Pro
When I push start the screen come upo black (in bios mode?) asking me to press F8 or F12. The only way I can get it to Windows screen is to unplug when it is in bios screen, replug and restart.
  • 3,267 Answers
Well continue in the same fashion and try starting in safe mode and restore it to the time when it was working properly could be the answer. If you have installed or removed any software recently could the reason so try to reinstall or remove as the case may be and restore your PC to when the software had been installed/uninstalled. If nothing works try to repair the OS using the original OS CD....sodeep
Posted on Jul 26, 2009
  • 202 Answers
May be a bad bios battery, try replacing battery loading setup defaults when this occurs and see what happens. the question i have is it a black screen or bios. if bios it probally is not holding settings and this is probally a bad battery
System won't boot up window XP
HI Joe. It's likely you have a virus. Or could be just a corrupted section of the hard drive. The F8 is what gets you to the black screen with the differnt boot options. F2 or Del button gets you in the the BIOS or start up instrutions for the PC. F 12 will get you boot device options. The F12 or F2 needs to be pressed before it ever gets to try starting windows. So when you first power on, immediately start tapping the F12 about once a second. This should bring up a menu of which items/ device, to start from. [If you get a stuck key message just clear it and continue tapping F12 or start over] I would suggest you use the windos CD and choose the CD device to boot from, then it will recognize the CD drive. You could follow the CD start up options to peform a repair of windows. If you do a repair, then you should also perform a virus scan immediately after. If after all that, you still have issues, then it's likely the hard drive itself is bad or going bad and you should look at replaceing it. Good luck.
Dec 05, 2012 | Dell Dimension 8200 PC Desktop
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Box have no problem i can,t connect to computer
software problem thn press F8 AT STARTUP & go in safe mode or repair XP
Else hardware problem thn clean sliver portion of ram by rubber
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
Mar 02, 2011 | Computers & Internet
When i turn on my computer a black screen pops up saying enter current password._ Unable to use f2 or f12 What am I supposeed to do
Hi
You could try to start up in safe mode ( quite often f8 ) sign in as administrator and cancel the password
Also if you get into safe mode try a system restore back to when it was ok
Or hit delete key a few times when starting up hopefully this will take you into the bios because the f12 or f2 key may be disabled
Be very careful what you change in your bios because on a laptop its not very easy to change jumpers on bios battery so only enable the f2 or f12 then hit save and exit windows will then restart
But be very very carefull not to play around in the bios if you dont understand it you may end up with BIG BIG Problems
Nov 13, 2010 | Toshiba Satellite Pro L300 Notebook
Windows XP won't start
Try starting it in SAFE MODE. Hit F8 slowly repatedly as it starts before windows screen comes on.
When you get into safe mode, drivers that may be failing are not started. Then you can look at the boot log to see what failed and remove that item so you cana restart normally.
You may have a virus.
IF you have created a restore point, restore while you are in SAFE MODE.
Oct 26, 2009 | Computers & Internet
Amillo pro 2010 screens gone black
Check by rebooting it to BIOS--Press Del or F1 during boot....
Choose F8 option during startup intial stage-Windows
Choose Safe Mode----If it works---then No Problem with Hardware,,but with Operating System--Repair or Reinstall Operating System using Valid XP Serial Key
Oct 01, 2009 | Computers & Internet
I just installed xp pro and it keeps freezing
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
Startup with F12
Welcome to FixYa! Delete is the BIOS setup key at POST. F12 is a one-time boot option. Safe mode is accessed by repeatedly pressing the F8 key at the first Windows splash screen. Post again if you have further questions. Steve
Aug 05, 2008 | HP Compaq nx6125 Notebook
Won't boot
Try pressing F8 as your machine gets ready to start windows. Keep tapping it until you get a menu. You can try "most recent settings that worked" or failing that try starting Windows in safe mode. If it will start in safe mode regress it to a point before your failed download using System Restore. If it won't start at all, you may need to reinstall Windows.
May 26, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Dell Dimension 3000 PC Desktop Logo
54 people viewed this question
Alun Cox
