Question about Dishwashers
My whirlpool dishwasher doesnt not drain completely empty
  • 44 Answers
Check grease trap[ located after l/panel is removed,it is a plastic container] have power disconnected first. if too much hardened grease is there thats your problem.where i live,only whirlpool contractors are allowed to repair same.come back to me if this is the problem.regards
Posted on Jul 26, 2009
Water sits in bottom
If water does not drain at all then the drain pump could be blocked.
If only a little water is remaining but cycle is complete, then this is normal.
However, do check the kitchen drain is clear and you do not have a garbage disposer (insinkerator) in sink which is full. Normally empty it before you start the dishwasher.
Do you get any alarms (lights flashing etc)
Jan 03, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
I HAVE A WHIRLPOOL DISHWASHER MODEL DU890SWKU0, MY QUESTION IS: EVERYTHING WORKS BUT THE WATER DOESNT GET FULLY DRAINED WHEN CYCLE IS COMPLETE. WHAT CAUSES THIS? THANK YOU
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Whirlpool Dishwashers
My whirlpool quiet porter II dishwasher doesnt drain completely
not much info to go on but here goes...usually that problem is because the drain line into sink or whereever is too low. must go up from D/W soonest and go as high as possible.then into drain system.prevents drain back into D/W.also drain can be plugged up.. (hose) good luck ...paul
May 21, 2010 | Whirlpool Dishwashers
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Doesnt empty completely, a pump is running when
it is normal to have some water come back in from drain hose(not to worry)
Aug 23, 2009 | Whirlpool 18 in. ADP530 Free-standing...
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Whirlpool QP II dishwasher - Not draining
I had the same problem... I jiggled the washing machine.. the discharge hose seemed to be clogged.
Oct 21, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool dishwasher
I had the exact same problem with my Whirlpool Quiet Partner IV. I removed the lower arm, and a couple of components below that, and got to the filter/grinder (that thing that chops up and filters the recirculated water before it goes to the pump that feeds the arms). The filter was completely clogged. I used a knife to scrap away the foodstuffs, put everything back together and all worked excellent. Just goes to show you that you should rinse your plates before to place them in the dishwasher.
Mar 14, 2007 | Whirlpool 24 in. DP840SWP Free-standing...
Dishwashers Logo
258 people viewed this question
Top Dishwashers Experts
Owen Barnes
