Question about Sony BDP-S350 Blu-Ray Player
I putting my blu-ray disk in and on the front of the player it says no disk. On the screen itself under video it says BD Data Ext memory in the Ext jack on rear of unit not reconized. Check exy memory turn the power off then on again. However there is no ext memory there at all. Help!
  • Sony Master
  • 19,396 Answers
To view extra content on some blue ray disk you need an USM1GH Memory Vault unit connected at the back of the blu ray unit.
To use features on certain BD the player may need a Sony USM1GH like the one below:
Note: If the Blue Ray does not read any disk , then the problem is not the external memory, in that case call Sony ringing the number listed on the owner manual.
Posted on Jul 26, 2009
My player wont load rented blu rays. I have cleaned the lens, done all the unplugging and replugging, and i have loaded older blu ray disks successfully. going to try a hard reset now.
hi donald.
this is all i could find at the mo,so not sure if this will help you out.if not go to the link and the bottom of this page might help you as well.
Blu-ray disc won't play on Blu-ray player [ Edited ]
Options ‎03-01-2013 09:34 AM - edited ‎04-08-2013 05:42 AM
If you are having problems playing a blu-ray disc is your blu-ray player, try the following.
1) Check the firmware-make sure you have the latest version. If your BD player uses the Xross media bar, following these steps:
Press the Home button.
Select setup
Select System Settings
Press the Enter button on the remote.
Scroll down and select System Information and press enter.
The Firmware version will appear on the screen. Write this number down and go to esupport.sony.com to see if you have the latest version. Just follow the instruction to perform the update. Check out this video.....it will walk you thru the steps I just described.
http://www.youtube.com/watch?v=0lI2IaK3XkA
2) If your BD player doesn't have internet connection, you can check the firmware version by:
Press the System Menu button.
Highlight Setup and press the ENTER button.
Highlight Video Setup press the ENTER button
Highlight TV Type and press the ENTER button
On the remote, press the Blue button
The current firmware version of the player will display. Write this number down and go to esupport.sony.com to see if you have the latest version. Just follow the instruction to perform the update. Check out this video.....it will walk you thru the steps I just described.
http://www.youtube.com/watch?v=kOq-zba_-5c
3) Some BD players requre that a USB memory device is inserted in the EXT slot of the player prior to playing the movie. It's recommended to use at least 1GB. If you already are using one and run into a disc not playing, try removing the USB device and plugging it back in.
Here's a few more things you can try.
1. Reset the BD Player:
  • Remove the disc from the BD player.
  • Turn off the BD player.
  • Unplug the power cord of the BD player from the electrical outlet.
  • Let the player remain without power for one minute.
  • Plug the power cord back into the electrical outlet.
  • Turn on the BD player.
  • Insert the disc into the BD player
2. Make sure that the Parental Control settings are not set to "On".
3. If the BD player supports the BD-Live feature, set the BD Internet Connection setting to "Do Not Allow" and delete any conflicting BD-Live date from the BD/DVD Viewing Settings menu.
won load rented blu rays Google Search
Nov 03, 2017 | Televison & Video
My BD530 player doesn't play all movies clearly. Some come cover good others re all snowy
When properly connected to a High Definition display or TV, Blu-Ray Disks (BD) should play crystal clearly. Inserting an old "non-Blu-Ray" disk (or the original "DVD") in the Blu-Ray player will display a comparatively "fuzzy" picture. This is the difference between High Definition and Standard Definition. A "BD player" can not "upgrade" the picture quality on DVDs to that of a BD or High Definition picture.
Rent, purchase or choose Blu-Ray Disks (BD) whenever a choice is offered to view the High Definition version of a movie or video. Selecting the DVD version will provide the lower quality or Standard Definition version of the same movie or video.
Check the covers or disk itself to determine if the movie or video is in DVD or BD format. That will tell you what you can expect for picture quality.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 17, 2011 | LG Super Blu BH200 Blu-ray and HD-DVD...
Hi there , I am trying to watch Planet Earth blue ray disc on lg bd 390 and for some reason any of the discs does not load (there is 6 of them).i thought it was a bad product and I asked for an exchange...
Try disabling BD-Live.
On the LG BD390 go to the Home screen then select the following:
Settings-->Network-->BD-Live Connection
You have three options: Permitted, Partially Permitted (default), and Prohibited.
Change the setting to Prohibited.
Now reload the disk and try again.
If that doesn't work try clearing the BD Storage (memory about the disks you play).
Again from the Home screen:
Settings-->Others-->BD Storage Clear
I think changing the BD-Live setting will stop the problem you're experiencing. If that works, you could also try changing the setting to Permitted.
I am experiencing issues with some of the very latest Blu-Ray disks, such as Avatar and Date Night. I don't have enough experience to be sure yet, but so far the evidence points to a new setting or standard in the disk industry that does not play well with the Partially Permitted default setting on the LG BD390 and a few other Blu-Ray players.
I hope this helps. Good luck.
May 22, 2010 | LG BD390 Blu-Ray Player
During upgrade download my electicity cut causing
According to the manual if you press the( >>I ) button on the front of your unit for more than 5 seconds without a disk inside it will set everything back to factory. It say don't use it unless necessary. When the factory default settings are restored all the user data stored in the persistent memory will be deleted. If its not working I don't see what you have to lose.
Mar 02, 2010 | Samsung BD-P1500 Blu-Ray Player
Ext memory message when external memory has never been used.
I tried all the fixes out on the net and called sony product support. They offerered to sell a different refurbished product for $150 plus shipping and handling. I WILL NEVER BUY A SONY AGAIN.
Jan 15, 2010 | Sony BDP-S350 Blu-Ray Player
Want to update my sharp blue ray disk player bd-hp21u - does not play current disks
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
  1. Insert the USB memory device
    with the update file into the BD
    STORAGE/SERVICE terminal on
    rear of this player.
  2. Press SETUP to display the SETUP
    MENU screen.
  3. Press arrow keys to select
    “SETTINGS”, then press ENTER.
  4. Press UP/DOWN keys to select “SOFTWARE
    UPDATE”, then ENTER.
  5. Enter the 4-digit number using 0-9.
  6. Press ENTER to start checking data
    in the USB memory device.
  7. During the data checking,
    “Checking” blinks.
  8. The current version of this unit software
    and the version of the update file on the
    USB memory device are displayed. To
    update this player software with update
    file, select “YES”, and press ENTER.
  9. If the USB memory device is not
    properly installed or the correct update
    file cannot be found on the USB
    memory device, an error message is
    displayed.Check the file on the USB memory
    device, and then reinsert the USB
    memory device correctly.
  10. Press ENTER to start updating.The screen becomes dark for a
    while until the update screen can be
    displayed. Please wait for the update
    screen to appear. Do not unplug the AC
    cord
  11. When the software is successfully
    updated, a screen is displayed
    indicating that the update process is
    completed.If the update has failed, check the file
    in the USB device and try Software
    Update again.
  12. Press POWER to turn off the player.
  13. Remove the USB memory device.
Oct 18, 2009 | Sharp BD-HP21U Blu-Ray Player
Bought s350 blue ray dvd player. when tried to play ,get error message- EXT MEMORY IN TH THE EXT JACK OF THE REAR OF UNIT NOT RECOGNISED. CHECK THE MEMORY AND TURN THE POWER ON AGAIN. NO EXT MEMORY IS...
I had the same issue. it is not recognizing the disc. I called in and I am having to send it in for servicing. The message you are getting is because the only option you are getting is the BD data one and not the one to play the disc.
Jun 05, 2009 | Sony BDP-S350 Blu-Ray Player
Not playing blu ray discs
Did the Live Chat with Sony, and they said if you reset the unit (unplug it for a minute and plug it back in) that should fix the issue. If it does not (in my case, it did nothing) the unit needs to be sent in for service. I'm taking mine back to the store in hopes for a refund. Good luck!
Dec 21, 2008 | Sony BDP-S350 Blu-Ray Player
Sony BDP-S350 Blu-Ray Player Logo
287 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
