Question about Whirlpool Calypso GVW9959K Top Load Washer
How do I replace the water intake valve on my whirlpool top loader.
    President:
  • 1,776 Answers
Whirlpool, Kitchen Aid, Kenmore, Roper, Estate, after 1985
• The valve will be mounted to the back of the washer with two screws. However, you must remove the valve from inside the washing machine, and this requires you remove the entire washer cabinet, which consists of the top, front and sides.
• Remove the two screws in the lower corners of the control panel.
• Lift the control panel up high enough so it stays up and back.
• Disconnect the wire harness connector.
• Using a flathead screwdriver, snap out the two gold-colored spring clips at the top of the cabinet on the left and right sides.
• The cabinet will now lift up at the back. Pull the cabinet up 10-12 inches and then slide it forward 2 inches.
• Remove the cabinet completely and set it aside.
• The valve will be on the right side of the washer at the back. It’s the device to which the water fill hoses are attached.
• Label the wires from the valve and remove them.
• Remove the water feed tube(s) from the valve.
• Remove the screws holding the valve to the back panel.
• Install the new valve in the reverse order.
• Reinstall the cabinet. (Note: As you follow this procedure, do not force the cabinet in any way. When done properly, the cabinet will go back together very smoothly.) First, tilt the cabinet toward you 10-12 inches while you “walk” the cabinet back onto the lower frame of the washer. (This will be easier if you have the washer lid open so you can see inside the cabinet at the same time.) The front edge of the cabinet slides underneath the base frame, and the sides of the cabinet rest on top of the base frame.
• When the cabinet is resting on the frame squarely, check to be sure the back of the washer is aligned with the cabinet. There are two plastic strips attached to the back of the washer that must line up with the sides of the cabinet as you set the cabinet down.
• Reinstall the two spring clips at the top.
• Reattach the wire harness connector.
• Rotate the control panel back down and reinstall the two screws.
• Flush out the water fill hoses.
• Reattach the water lines.
• Turn on the water.
• Check for and correct any leaks.
• Restore power and test.
Hope this helped you and best wishes.
Posted on Jul 26, 2009
Duet whirpool front loader is filling with water on its own
The washer fill valve is defective and will need to be replaced. The fill valve is right under the main top at the back the fill hoses attach to the valve.
Oct 07, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Water continues to flow into my whirlpool top loader serial #2dwtw4740yq0
Your inlet water valve likely needs replaced. The water supply hoses behind the machine attach to the the water valve on the machine. You will need full model number usually found around inner door to find correct valve.
Jan 11, 2013 | Washing Machines
Maytag washer leaking water into tub when idle
A intake water valve is leaking and will need replacing.
Dec 30, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How to replace water valve in washer
You're probably talking about a top loader. Rarely do you have to change water valves in front loaders because they're too new. You go to the back of the machine. Take off all the screws on the back neck and on the top if they're there. There's your valves. NO POWER . Make sure your hose is disconnected and the water valves are turned off Unscrew, disconnect connectors. (doesn't matter which way they go back.)
Replace and reverse.
Feb 15, 2012 | Whirlpool Washing Machines
When my machine gets to its rinse cycle it works for about 30 seconds and then all the lights start flashing and it stops working
You most likely have a faulty cold inlet valve. When the machine gets into the rinse cycle, it needs to fill up with cold water.
Depending on whether you have a top loader or front loader, there may be a seperate valve for the rinse water intake on a front loader.
Let me know the make and model of your machine and I can help you identify and replace the inlet valve.
Regards
Ash
Nov 15, 2009 | Washing Machines
Water goes into the washer even when the washer is off
Yes , the valve is stuck. take top cover off to get to it by removing 3 or 4 screws from top rear and replace.
Phil
Apr 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a duet f/l loader. The washer fills with water when not on
I FOUND THE PROBLEM WAS THE VALVEWHICH CONTROLS THE WATER INTAKE ON THE TOP OF THE WASHER. I PICKED UP THE REPLACE VALVE IT WAS LOCATED AT THE TOP OF THE WASHER WHERE THE WATER INTAKES ARE. THIS SOLVED MY PROBLEM.
yOUR SITE WAS VERY HELPFULL
THANKS ****
Nov 26, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
627 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
