Question about Acer TravelMate 2451WLMi Notebook
Problem with mouse and keyboard
My keyboard stopped functioning also the touchpad what can i do i resoldered the motherboard already
  • 202 Answers
You either loosened the cables going to the board for the keybboard and touchpad or have a briged solder joint.
Posted on Jul 26, 2009
Keyboard, touchpad and external mouse stopped suddenly..for Toshiba satellite l3900
Press function key on keyboard F5 to see if this helps turn on mouse / touchpad
Jun 21, 2016 | Toshiba Computers & Internet
Tip
How to Fix Touchpad on a Laptop
<p><span>The touchpad of your laptop is a most important and frequently used input device. If your touchpad stops functioning, it may be difficult for you to use your laptop. Touchpad normally faces following issues. <br /><br /><b>Laptop Problems and Their Solutions</b><br /><br /><b>Problems with the driver</b><br /><br />Computer hardware communicates with your computer through real time software called driver. Drivers control computer hardware. It is possible that virus or human activity may damage the driver. You can check your driver's status through computer's device manager. You'll see a yellow color indication under "Mouse and other pointing devices" heading. You can download new driver form your laptop's manufacturer website. <br /><br /><b>Problems with connection</b><br /><br />Touchpad's connection with motherboard is delicate. It can be broken due to heating and other inner problems. So, if there is no problem with the driver, then the connection of the touchpad to the motherboard may have broken. <br /><br /><b>Misuse</b><br /><br />Touchpad of the laptop is the most delicate input device. Some people tap on it too hard or use a shrill tool as an alternative of a finger. This can damage the pad. <br /><br /><b>Fn Keys</b><br /><br />Touchpad driver is slightly different from the other devices that need drivers to function properly. It came with an operating system that you don't need to re-install it. Laptop keyboard comes with many functions than the common keyboard. It has Fn keys which are called function keys. Sometimes, your laptop's touchpad stops working because you accidentally hit some one of the Fn keys. You can follow these instructions to make your laptop touchpad working again. <br /><br />1- Search for Fn key on your laptop keyboard. It is commonly located next to the Ctrl key. <br />2- Now search for F1 to F12 keys on the laptop keyboard. These keys control sound, brightness of the screen, wifi etc. They are located on top of the keyboard. Look for the key which has icon on it that looks similar to the touchpad. <br />3- Let's take an example of Toshiba laptop. It uses F10 key to enable or disable touch-pad. Hold down Fn key along with F10 key to enable the laptop touch-pad. <br /><br /><b>Cleaning the laptop touch-pad</b><br /><br />It is a good practice to clean your laptop touchpad. To clean it, take a cloth dampened with sprit. Wipe your touchpad off with that cloth. <br />Laptop touchpad work best in moderate temperature and gasping environment. Moisture, excessive heat, can damage it. Try using your laptop with tidy hands. Sweaty and dirty hands can cause problems. <br /><br /></span><span><span> </span></span><br /><span><br /> </span>
on Jan 06, 2011 | Computers & Internet
Touchpad
Just look out for a mouse-pad symbol on any of the function key of your keyboard.
And then press the 'fn' key on your keyboard with that key which has symbol of mouse-pad on it. I guess you will be able to access your mouse pad.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
May 06, 2013 | Dell Inspiron 1300 Notebook
HP DV9700 Mouse
Click Start/Control Panel and look for the Mouse and open it to check the mouse properties. Make sure you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and Hold the ALT or FN function key located at the lower left portion of the keyboard, then hit the key that toggles the touchpad. The correct key to hit will have the icon of a finger pointing at a square that represents the touchpad.
Download and reinstall the touch pad drivers.
Get online and got to www.google.com In the google search box type: "HP Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers.
May 18, 2012 | HP Pavilion dv9500 dv9600 and dv9700 FF...
My Acer Aspire 5732z inbuilt mouse works and stop, why?What is the solution to this problem?
Hi faithfulnice...
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 11, 2011 | Computers & Internet
Touchpad not responding in netboook
There's a little button right above the touchpad. If the light on this button is orange, the touchpad is disabled. Press it again until the light is white again and your touchpad should work.
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
Touchpad is not responding and keyboard
Try shutting down the device and taking out the battery for 10ish seconds. Reinsert it, and power up your laptop. Sometimes this method takes 2 tries, but usually corrects the power/allotment conflicts keyboards and touchpads have with HP motherboards.
Aug 20, 2009 | HP Compaq nc6220 Notebook
Laptop mouse stopped workig ??
In your case it maybe that the mouse is disabled, this is done with a function key, FN and one of the F1- F12 keys.
make sure the mouse is not disabled.
if this doesn't solve the issue.
it may possibly be:
  1. Software issue.
  2. cut cable.
  3. broken touchpad.
  4. issue between the touchpad and motherboard.
  5. faulty motherboard..
Jan 16, 2009 | Toshiba Satellite Pro P300 Notebook
Aspire 3100 touchpad and mouse not working
Try doing complete format and install a fresh copy of Windows XP and dont use the recovery CD.
Thankyou
Feb 09, 2008 | Computers & Internet
Trouble with touchpad & dvd functions
you probably need to reinstall the drivers.
Nov 11, 2007 | Acer Aspire 5610-4648 Notebook
Acer TravelMate 2451WLMi Notebook Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
