Question about RCA D52W19 52" Rear Projection Television
52 projection tv
52" projection tv power comes on 3 times for about 3 sec each time then goes off. you haft to wait about 30 seconds and it will do the same thing when you hit power button. Power never comes on and stays
Slinteriors
  • 8617 Answers
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Posted on Jun 29, 2008
the circuit board behind the power on and off button needs to be replaced very easy fix.. good luck everyone
Posted on Jan 09, 2009
SOURCE: TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Posted on Jul 31, 2009
Slinteriors
  • 8617 Answers
SOURCE: 52"rca hdtv lights blink will not turn on
Thats the classic sign of the CP150, CP120 and CP114 capacitors having failed. By trying to power it up over and over the caps will eventually charge and the set will function untill you power it down. You can get the CP150, CP120 and the CP114 repair kit at www.tvrepairworld.com and the kit contains the CD with repair instructions.
Posted on Dec 17, 2009
Testimonial: "thank you very much very helpful will order these parts& try it"
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Dec 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Got the tv stanby Working
The ribbon connector which goes from the FMT to the DM is disconnected or not seated properly thats the only thing that will cause the 4 4 error other than a broken ribbon socket
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
RCA D52W20 tv
3 capacitors On Deflection board cp150 2200uf 16v see if it is puffed up on top if so it is bad also replace 2 more caps in same circuit cp114 cp120 both are 220uf 35v they are green with gold writing.For Parts 1-800-223-3205. www.electronix.com
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
Tv will not come on immediately...
3 capacitors cp150 2200uf 16v if it is puffrd up on top then it is bad ,other 2 caps cp114 cp120 220uf 35v they are green with gold wring on them located on Deflection board . Resolder all pinns on FBT on same board.
Dec 26, 2008 | RCA D52W19 52" Rear Projection Television
Tv does not come on
IT SOUNDS LIKE A FLYBACK NEEDS REPLACED (PART COST AROUND $70.00
Dec 06, 2008 | RCA P52960 52" Rear Projection Television
TV will not turn on.
Bite the bullet, because it's time for Santa tech to work on this and find the reason for the power supply problem..accordianman
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Tv will turn on
leadfoot,
i believe the problem is the flyback transformer. try cleaning by using a small aerosal can. this will either correct the problem or you might have to replace it.
flyback transformer stores energy so i would suggest hiring a professional technician.
Nov 20, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W20 tv will not turn on
mine does the same thing obviously it is a high voltage problem with the power supply or flyback transformer,we have power outages all the time more thank likely it was the colprate good luck ,my suggestion do what im doing throw it in the trash and buy a new one ,it will cost more to repair we live in a throw away society they dont make anything worth the crap any more ,tvs used to last 25 years now if your lucky 5.
Aug 21, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
178 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
