Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Motor spins, shaft does not...
Not only did the line keep coming off of the trimmer, but the grass hog trimmer jammed but the shaft kept turning. The stem that the dual line unit attaches was stripped in the process and now the the shaft spins but the dual line system no longer rotates.
I checked Black and Decker's website to order a part but it is not offered as an individual component. It is sold with the main section of the trimmer. I would have to replace most of the trimmer to fix the problem. I doubt I will purchase a trimmer from Black and Decker again, as a result.
I'm in a similar situation with my GH1000, except that it was a part that comes with whole motor assembly. I could sell you the shaft assembly of my trimmer, or I'll buy your motor assembly. Yes?
Posted on Jul 26, 2009
The motor is working but the trimmer part stopped spinning. I checked the line but there is plenty, I removed and replaced the line spool but still not working.
Does the trimmer head spin freely? If so then it is somehow disconnected from the motor. There should be a motor coupler somewhere near the motor and also near the trimming head. Make sure they are connected.
Jun 06, 2011 | Black & Decker 14" Grass Hog Xp...
Put in replacement spool cutting great as usual went edge the head with spool of line wont turn went back to normal position spool will not spin to cut motor runs spool head not engaging how can I fix
pull the head completely off and make sure that the shaft is not broken, if not then line it back into the head slot and put back together and test it out, Tim
May 29, 2011 | Black & Decker 14" Grass Hog Xp...
How do you take apart the B&D H1000 Grass Hog XP to get to the inside to replace the shaft? I thought I had removed all the screws but it still won't come apart. What am I missing? Jim
Jim-
From other google searching i found this:
"Charles, there's an additional screw under the label that instructs how to turn or extend the shaft. A white line separates the 2 instructions. The screw is directly above this line. Just punch through the label and you'll find it"
Apparently once you get inside (that's how i'm spending my weekend, too), it's $53 to replace the motor and gear. $69 for a brand new one...
k
Aug 07, 2010 | Black & Decker 14" Grass Hog Xp...
I just bought a BD Grass Hog and after 1 h of use,
If the noise was up by the handle it may have been the drive pulley breaking loose of the shaft on the motor causing the motor to spin and stop the flex shaft of the trimmer. Another possibility would be the small belt that aids the flex shaft. If those don't fix the problem check the lock nut that bolts the flex shaft to the spool housing. If the shaft broke free from the housing the motor would still run and the shaft would turn, but the spool housing would not spin if it does it could be stopped very easily. Definately check the warranty.
Jul 07, 2010 | Black & Decker String Trimmer Cordless 12"...
I have replaced the line spool with a new one and it will not run
hey mate, the best thing to do would be try eliminate sections if the head does not spin remove it see if the arbor that the head connects spins with the head removed, if it still does not spin remove remove your drive shaft and check if motor actually spins some of these contain sheer pins to prevent damage to the motor, I would highly reccomend this be done by a professional as there is moving parts and electric motor involved... hope this helps
Brad:)
Sep 20, 2009 | Black & Decker 14" Grass Hog Xp...
We were trimming our grass and the line stopped spinning
flex shaft most likely broken check online or at a local lawn and garden shop the are normally not too much and somewhat easy to replace
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
sounds like the cable has broke inside the tube or it popped out of place. loosen the bolt on the motor casing holding the tube and separate the two pieces and pull the cable out. Should be a square at each end of cable.. if not post again
Jul 23, 2009 | Black & Decker 14" Grass Hog Xp...
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
507 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
