Question about GE WSXH208A Front Load Washer
Ge front load washer, 7 years old
The front loader won't spin. it agitates, and drains well. We cleaned all the hoses and got 5 bucks of change out of it. Also a guitar pick was caught in the pump. When we got it back together it still does the same thing. Thank you for your help.
    Champion:
  • 249 Answers
Speed control module faulty replace it .Close Ireland bye bye
Posted on Nov 22, 2007
Drum will not spin
did he run the diagnostics per the tech sheet within the machine?if it will do everything else but spin out,then the drain pump is plugged,as a plugged drain pump will shut down these front load units,you will need to remove hoses off pump and clean out pump and all hoses from tub to drain stand pipe,by running the diagnostics you can run each washer cycle and see what cycle isnt performing in a matter of 5 minutes versus 1 hour real wash time on some cycles
May 01, 2012 | Kenmore HE2 Plus Front Load Washer
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
My washer fills , sits, does not agitate, empties and spins.
I had the same problem. Take the agitator off by pulling on it extremely hard - use allen wrenches in the slots on the sides to help. This exposes the "air bell coupler" - take the 7/16" bolt out and slide it off. Chances are the spline is stripped out inside. The part is 5 bucks online
Feb 01, 2009 | GE WJRR4170E Top Load Washer
I have a 2 year old frigidaire front load washer.  The spin cycle starts, but only runs really slow.
all washers must drain before will go into high spin.is your's draining?the front loader type's of washers are good for getting the pumps blocked up with stuff that was in our pockets etc....too get to the pump remove the bottom front panel.the pump is the white or tan unit with two hoses to it and two wires on the right side of the washer..there are some bolts retaining the pump to the washer floor.remove and remove hose and drain into a bucket.then clean out pump.if you turn off water at house fill hose's you could put in spin at that point to test.then put all back together.if you need more advise you can email th-u fixya. God bless ,tom
Jan 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Atf 6000 front loader not spinning or draining
HI .you probably have a no drain problem. remove bottom panel. the pump is on the right. put drain hose on the floor, in a bucket, drain water out. check the pump. remove the hoses to the pump. clean out. thanks the appliance doc please rate my answer.
Oct 07, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
GE WSXH208A Front Load Washer Logo
46 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
