A musty smell almost mildew when using it in the Dry mode. Mr Slim split 30,000 btu
  • robert330 Jul 27, 2009
    Thank you for your in depth response. Excuse my ignorance but it sounds like you are referring to an HVAC ducted system. Mine is merely a split with the controller in my apartment and the compressor on my roof. I definitely know a qualified contractor who installed the unit but I don't think he has your experience in killing molds which is extremely important to me. Does the work that your suggesting take place at the controller or the outdoor compressor? If it's the compressor how do I insure that the UV light will not get wet?
    Thank you
  • 3,037 Answers
Dirtys sock syndrome is bacteria growing, usually in the coil and pan area. The solution is for your to do a thorough cleaning of the indoor coil, pan and drain, using a good, stiff mix of coil cleaner and disinfectant, like Lysol. The entire area must be kept WET for at least 10-minutes and then be thoroughly rinsed to flush away the bacteria."
What would solve this problem permanently after cleaning the coils is to install an ultraviolet C lamp just above your evaporator coil. You can do it yourself very easily. The things are readily available on the internet (Carrier/Bryant and Aprilaire) for about $250.00 or you can have a contractor do it for about $500.00 (systems up to 3 tons) Add about 50% to this figure for a 4 or 5 ton unit which should have a double lamp system.
Some added information on the lamp.
There are several schools of thought about what these lights will and will not do. Distilled to simplest terms--they won't kill germs or mold "on the fly" flowing through the air stream of your hvac system with any precision. They will kill mold and bacteria on your cooling coil, keep your drain pan clean and improve the heat transfer ability of your coil by keeping it free of the nasty black junk that always seems to grow on coils that don't have a uv lamp. This should eliminate any mold smell originating from your cooling coil and prevent subsequent "seeding" of such organisms to distant parts of your system. It WILL NOT fix problems with existing mold in your ductwork past the area the lamp is installed. Your ductwork should be thoroughly cleaned to fix this (and make sure it is not unconnected somewhere which could cause condensation and mold).
Let me know how this turns out.
Benjamin
Posted on Jul 26, 2009
  • Benjamin Patri
    Benjamin Patri Jul 27, 2009
    You can get outdoor UV light units, it would go on top with the compressor, or something can always be custom made
Mitsubishi electric Mr Slim wall unit heat and air. strange smell coming out when air is on, we cleaned filters, but do not know where the heat exchange is or the the fan to clean them
Ductless split systems are know for creating a mildew looking "stuff" on the blower wheel. Try to open/move the louvers on the front of the indoor unit. By opening the "osculation blade"/louvers, you can see the blower wheel, normally blue in color. See if it has some mildew growing on it. If so, I found that a tooth brush and about 2 hrs labor does some good. I've found some aerosol spray, called mildew removal. Works great at covering up/controlling the smell. It's also possible that the unit is pulling air from the condensation drain line. These lines can for algae, and give us a sour yuck smell. To clean, use a wet vacuum, and clean from the outlet of the drain line. Hope this helps!
Aug 21, 2017 | Mitsubishi Heating & Cooling
How does one access the drain pan in a Mr. Slim? I think I have stagnant water (minimally), mildew or mold somewhere and nee to make sure.
POUR some strong bleach water in it where you saw the second guy put water in . that should kill any bacteria if there is any
Aug 06, 2015 | Mitsubishi 9000 Btu Mr.slim Ductless Mini...
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
Horrible musty smell
try to find the filter or look it up on the internet.
Dec 17, 2013 | MSZ-A17NA 16,200 BTU, Mr. Slim Wall...
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Does this unit have capity for an 1000 sq ft room? what is this unit?
input is 30,000 Btu's. Output is probably 20% less. You should expect 15 Btu's per square foot. I would say you are fine, but not knowing where on planet earth you are so anyone would be guessing.
Dec 11, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr slim unit in bedroom 9kbtu - room 11x12'- is humid, awful
Lets clarify. DRY mode only dehumidifes that air and does not cool. Cool is used for cooling. Dry mode doesn't normally have temp control; it is automatically set by the unit. I think 9000btu is a big unit for the room; it is overkill. I would switch to a 5000btu unit. it cannot be fixed and the BR unit needs to be uninstalled and the new unit needs to be re-installed. The price of commisioning, de-commisioning and new unit is something in which you will have to pay.
I take the time to answer your questions, so please rate me.
Thankyou
Mat
Aug 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Moldy smell to air
I have a maytag ac unit that kept smelling moldy. We tried spraying with antifungal, only helped for a short time. I took the unit (ac unit slides out of window case) outside and carefully removed screws only to discover the fan was covered in mold!!!! Oh my what a horrible discovery! I washed the fan blades with bleach and water mix. I completely and carefully washed and wiped down the air conditioner careful around the control box. Then I let the unit sit outside in the sun untill completel dry. Good bye mold and fresh clean cool ac!! I will do this each year now that I saw that ugly mold!! That is definetly a health hazard! I would reccommend you either thouroughly clean your unit or pay someone to do it or get a new unit right away!! Don't use that moldy unit another day!! Good Luck!
Oct 03, 2006 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
