Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Just installed a Moen shower fixture, & the knob for the shower head doesn't send water to the shower head-- I don't get it!
  • deogee Jul 27, 2009
    Thanks for the reply SuperDave, but my problem is with the diverter to send water to the shower head.
    Some genius of an engineer designed the diverter to only turn 90 degrees, so you have your choice, water out of the tub spout, or no water at all. No matter which way you turn the diverter, there's a plastic stop that only allows for 90 degrees worth of rotation. (180 degrees would be nice, I'd be done with this job, & the folks I'm doing the work for would be able to take a shower instead of baths.)
    Moen has parts Fed-Exing to me for Weds-- hope they get it right this time. WHY would you even ship a shower fixture with a diverter that's engineered wrong to begin with??? Makes FedEx happy tho. Hope this new part works.
I just installed one this weekend. Make sure that the cartridge has the embossed "HC" at the top (for Hot on left, Cold on right) when you slide it back in. Also, before putting the handle on turn the cartridge shaft so that the completely flat part is toward the top and the side with the small notch at the end is toward the bottom.
Posted on Jul 27, 2009
Am installing a Moen hand held shower ("Propel"). The instructions say I should install a backflow preventer. Where does that get installed? Inside the wall, or on the shower fixture itself?
Just buy a backflow preventer and install it in-between the pipe coming out of the wall and the shower head. Most (all?) shower heads have 1/2? standard pipe thread. Home Depot sells a backflow preventer with 1/2? standard pipe thread for $6.97.
Good luck and hope this helps.
Dec 27, 2017 | Moen Home
We had both the shower and the Bath tub remodeld and installed new Moen faucets with a single knob that turns right to left to open. All was fine for a couple of days but all of the sudden they startd...
You need to install a new moen cartridge its a single handle posi-temp cartridge you should be able to get 1 for free if you are the original owner by calling 1-800-buy-moen more than likely when soldering in the new valve a little bit of solder broke free into the cartridge or hard water. When the water gets turned off and then turned back on it can break free alot of particles that can get jammed up in these cartridges or any fixture for that matter you will need a cartridge puller to perform this job with ease.
Aug 27, 2011 | Moen & One Handle Tub & Shower Faucet
I just installed a Moen Traditional 82008BRB faucet and shower. After having it installed for a day, water will drip (20 or so drops) out of the shower head every 5-10 minutes. This also occurred when I...
HELLO- Very possible that there can be dirt or solder inside, hard to determine without looking inside at the sealing points of the vavle itself. Try to determine if it is the hot or the cold side,also look at were the valve seals off ,could be small imperfection in the seal ! Good luck
May 17, 2011 | Moen & One Handle Tub & Shower Faucet
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Shower head and bathtub faucet both running when showering
Sounds like diverter valve which is your shower handle valve is bad take it apart and check out and replace it if possible because that transfer water to shower head.
May 01, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Leaking shower head
Check the spout pull knob . Debris can be keeping it from closing completely.
Jul 05, 2009 | Moen & One Handle Tub & Shower Faucet
Shower leak is it possible from Moen diverter to shower head
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
May 28, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
238 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
