SOURCE: Kohler whirlpool 5' tub
Here is the link to the Kohler 1209-LA jets exploded view:
Kohler 1209-LA
Hope this helps!
SOURCE: How to identify make and model of old whirlpool tub?
This is a problem common to all whirlpool/air jet style tubs. The pumps become air locked due to the water evaporating from lack of use. All tubs need, and have, SOME means of priming the pump, this is most likely what the problem was, originally, for you. This time in particular you found it to be electrical in nature but for future reference, for you and all who have these style of tubs, I am putting this out there. Some where on the tub, usually along the top edge of the tub is a vent knob that controls the amount of air that the pump is allowed to mix with the water for the jets, usually by closing this valve all the way (tub needs to be full of water of course) and running the pump for a minute or 2, you should be able to get the pump pumping water again, if not you may need to do something else with your particular set-up to get it purged of air, the pumps in jacuzzi tubs are designed to pump water, not air, so if the motor is running but you get no jet action, your most likely air locked and need to prime pump/purge air.
SOURCE: Need Filter Queen Model 31 owner manual.
Majestic Surface Cleaner Manual
see other post i made for filter queen manual
SOURCE: how to change the water filter on a whirlpool
The filter is located in the kick plate. There should be a handle you need to turn and le filter will release. The handle aprt of the filter will seperate from the filter and need to be used on the new filter.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
