Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
Door latch broke on a maytag dishwasher # mdb8750aww.
I replaced the door latch assembly and reconected the switches and now the washer does not come on. in the display it flashes 2H and then later the display shuts off.
  • Maytag Master
  • 19,396 Answers
2H is not an error code. The 2H that appears on display probably indicates that the delay is set to two hours on display. Turn off the appliance for ten minutes then connect back power. This should reset the control board and fix the problem.
Regards.
Posted on Jul 26, 2009
I changed the handel and switch assembly on my dishwasher because the old one was broke.The dishwasher does not turn on. It still doesn't work. it doesnt even light up. although one button does glow a...
check for line voltage at the door switches and from there to the control board thats to the right of the door latch switches for line voltage,if you have line voltages in all these areas then replace the front membrane push button control panel that connects to the control board
Jan 31, 2011 | Maytag MDB9600A Jetclean II Built-in...
Have a maytag dishwasher MDB6600 AWQ -latch/handle broke - bought replacement but not sure how to install - can you help
Just did this myself .Need the right star screw driver to remove 11 screws holding the door inner liner
then you can access the handle latch assembly. You pull off the 2 wire connectors to the switchs that are part of the assembly. Slip connectors onto new assembly.Position the handle part thru the door and re attach inner liner. 2 of the inner liner top screws also hold the assembly in place.Unfortunely , this didn't solve my problem of the dishwasher not turning on.
Jan 06, 2011 | Maytag 24 in. MDB6600A Jetclean II...
Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
May 19, 2010 | Dishwashers
Maytag MDB7601AWW door will not latch
possibly need a new door latch assembly this is kind common on those maytags the latch assembly becomes defective or doesnt latch properly...W10130694 is the part number for the replacement part u would need you can see a pic of this part at repairclinic.com just enter the part number. you could purchase it there or online thorugh sears or etc... also check local they might stock at and be cheaper with no frieght shipping charges......to change this or check your assembly prob have to remove all screws from inside door usually a torx bit this will seperate panels and control will pop off.. hope this helps
Feb 06, 2010 | Maytag 24 in. MDB7601A Free-Standing...
How do you safely replace the handle on this MDB7600A dishwasher
Easy job. You'll need a new "latch assembly". I found one at appliancepartspros.com for $18+ and $7 shipping. Part #W10130695. More $ elsewhere. Procedure: Remove torx head screws on 3 sides of the door, then pull the interior part of the door away from the exterior a few inches at the top of the door. The old latch assembly (and the broken handle, now separate) can now be accessed easily. There are two wire connectors press fit to the latch assembly switches. Use a screwdriver if necessary to pry them off the old assembly, which is probably corroded somewhat. Do this one at a time and replace on the corresponding terminals of the new latch assembly so the wires don't get switched (or else mark them before removal.) Reposition the latch assembly, push the two halves of the door back together and replace the screws. Done. I'll note that the latch is positioned but not secured by two pairs of thin plastic "fingers" molded into the back of the control panel. Three of four fingers had sheared off. I didn't feel like spending $70 to $130 for a new control panel so decided to try doing without. The latch is secured by the two center screws at the top of the door, so as long as those are tight it should be fine.
Jan 02, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
How do I replace the latch on my maytag quiet series 100 dishwasher?
Unfortunately, the Maytag quiet series models have plastic latch handles that are prone to crack after time.
You should be able to order a replacement handle through a distribtor.
If you can, unlatch/open the door. Using a star screwdriver, unscrew all the screws on the inside of the door frame.
Once all the screws are removed you should be able to separate the inside of the door from the latch assembly.
From there you'll need to squeeze the latch handle together and replace it in. I'll warn you that it feels like you have to squeeze the thing so hard you might break/crack it on your own. It is a hard/tight fit if I remember correctly.
One last thing you may want to do to is check the food grinder in the middle of the washer. Sometimes the cracked pieces of the latch can end up there stuck in the grinder causing it to be louder than it should.
Hope this helped.
Nov 06, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Door lock
The MAH5500B Neptune does not have the door latch wax motor so you won't have the R11 resistor burnt...
With that said.. Maytag made the door latch assemby one complete assembly meaning that you cannot replace the micro switches, solenoid, etc. On the older door latch assemblies Maytag broke it down to all of the little parts, ie. 12002535 wax motor, etc. I imagine that this was to reduce the part numbers folks would have to store in inventory...
You stated that the door is not locking? Did you pull on it to verify this? or could the door lock indication be not working?
There are 2 microswitches in the door latch assembly, one lights the door locked light and the second actually tells the control board that the door is locked. It is possible that the door is locked but the door locked light does not come on...
It more than likely could be three things.. The door latch assembly, wiring or control board. I would take Neptune apart so you can have access to the door latch asembly See www.neptunewaxmotor.com for step by step photos. Put a volt meter on the solenoid wires and see if you get 120VAC when the door should be locked. If so, then the solenoid coil is probably opened up and you will have the replace the door latch assembly. If 120 VAC is absent then I would check the wiring from the door latch assembly to the control board with an ohmmeter (unplug Neptune to be safe while using ohmmeter) If wire continuity is good then I would suspect the machine control board.
Jul 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag
If the door handle appears loose, you could have a broken door latch which will prevent the dishwasher from running if the door is not able to latch properly. The latch usually has two micro switches that are pretty delicate. Not to accuse you of abusing your appliance, but if you're in the habit of slamming the dishwasher door shut, you could inadvertently break the switches in the door. The switch assembly and handle are sold separately, so you may need to purchase both. Let me know if this helps.
Jul 08, 2007 | Maytag PDB3600A Built-in Dishwasher
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
255 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
