Question about 2wire 2700HG-B Router (2700HGB)
Trying to get a user manual
I am looking for a user manual for this product cause I don't know how to configer the network key. If you can give some info on how to configer the network key that would be great also.
    President:
  • 566 Answers
Get the Basic Setup and Advanced Setup guides from QWEST support: http://www.qwest.com/internethelp/modems/2wire2700HG/modemDetail_2700_installation.html
Posted on Jul 26, 2009
I looking for netwrok key to active my connection
Hopefully network key will be located in the install instructions that came with adapter, if not that lucky, you mind find the "key" on a sticker on bottom or back of the router u r trying to connect to, copy the info down, then when installing device u see the network detected that you wish to connect to, select it, and click to connect,, then enter the requested info, as it asks for it to setup,, easy enuff,, but ,,, if key not found,,, and you are installing the router at the same time,, it can really be a bummer,, fortunately some routers/devices have eased the pain by having a button you push (generally on both devices you are trying to network),,when pushed basically opens the doors and drop the encryption/barriers to make the connection for you,,, if no magic buttons on hardware, and if u cant locate the key info u need you may have to call your Internet provider if the router/connection is their equipment,, like Cox cable , etc,, they will generally walk you thru the proceedure to do the hook up no prob,,, but if not their provided router/equipment,, you went out and bought ur own modem , router, as well as the wireless adapter,, ur on ur own,, you might give a call and/or make a visit back to the store you purchased it from and have them see if they can help ,,,, lastly,, if none of these suggestions work for you ,,, then it can be very dificult to get right if attempting to do by yourself ,, you would have to first access the setup/config of the router using provided Install utility CD from Manufacturer of the router, if no Disk is available sometimes you can access the router and go online to their site by connecting the router to your PC using a Lan cable, open your browser window and typing it's default IP address into the browsers address window box,,you can look that info up for specific devices by name of manufacturer and model number, generally there is default ssid and key assiged from factory for intial setup you can look up and use,, if the network is already existing and u are merely joining it for your first time you will need all the info that has been modified from the defailt and is currently assigned by network admin. or service provider,,, you might try using the usual IP address that is generally the default,,, type "192.168.0.01" into browser address bar and press "enter" and it should go to the routers online config program,, if so,, try"admin" for user name and "admin" if password is required to sign into their site,, then just fill in the blanks to enter the info it requests, assigning ur own choice of SSID (network name) or using ssid default which are usually name of router manufacturer like linksys, or dlink etc and u can do auto assign the key and use usb drive or disks to copy the info to network users when using lan wired connections or just choose ur own "network key/password" to manually assign key to the router/network,, be sure to keep notes and save the info u will need to install other device, then save and close out program,you can enter the same SSID and Key and which type of encription used in order to ensure matching settings when doing the setup and network configuration,of your network for computer's device ,,, I warned you,,, this last way can be really confusing,, hopefully you will get lucky, and find the key on the router and wont have to get that involved,, if you do have bad luck and are forced to resort to last method. I'd recommend getting professional assistance or at least hands on help, from a more experienced installer,,, hopefully you will find the info on the router somewhere and u can just type that in when asked by ur install program,,, lol ... good luck
Jan 22, 2013 | Edimax EW7811Un Pre80211n Wireless Adapter
Dap1522 ip config
Not sure what your question is, but if you are trying to find the router's ip address you can find it in the manual. Sometimes the ip address, default user id, default password is on a sticker on the side or bottom of the router. If you don't have the manual try the manufacturer's website.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals.
Maybe you want to know how to run IP Config so you can find the MAC Address of the router or Network Adapter. The Mac address in ipconfig will be the Physical Address (a series of 2 characters with a period or dash between them).
You need to get to a command promt (black window with white lettering) and type the command: ipconfig /all and press Enter.
Jun 05, 2012 | Computers & Internet
I have been trying to connect to Xbox Live through my Xbox 360 wireless network adapter and when I try to connect it simply says that the WEP key or WPA passphrase is incorrect, when it is indeed the right...
If you are getting an error that the WEP or WPA key is wrong, it's most likely NOT a DHCP issue. If you are 101% sure you are typing in the key correctly with no errors, there is a slight possibility that your router got reset somehow. (Did someone press its reset button?) If so, then the key stored in the router was wiped out, and of course, it wouldn't match now! If you don't know how to log into your router's config page and have no manual, try going to their website. Manufacturers post free PDF's of their manuals to download. You can also try shutting off the security temporarily (turn off WEP/WPA) and see if it connects then. Then re-enable it with a new passphrase. Hope this helps a little!
May 03, 2011 | Computers & Internet
Need a network key for my device sylvania wireless mobile interney device
I assume you mean that - When you try to connect to the internet at home, it is asking for the 'key'
This is the same key (like a password) that you used to set up your Wireless Router to connect to the Internet... Typically a WEP security key can be 26 digits long....
If you have a Router, try the handbook you got with it for the IP Address (like 192.168.1.1) typing this into your browser window should connect you to the Router, but you will still need to know the Login User Name (also in the User Manual along with the Login Password) for the Router.
Typically this could be Admin and Admin The User manual will give you all the information you need - not only for setting it up, but also for getting Online.
If you haven't got a Router connected to your Telephone line - chances are you are trying to connect to a neighbours Wireless system and this is not legal - which is why passwords (keys) are used.
Connecting to a FREE network - say - in MacDonalds - they will ask for some details about you and then GIVE you the key.
If I've completely missed the reason for your question, please come back and let me know, Thank you
Brian.
Nov 25, 2010 | Sylvania G-Netbook
I need a networking key to set up my lynskys wireless
do you own the network's router? if so, then simply visit the router's config page. to do this, turn on your router and connect a working PC. then in that PC, visit http://192.168.1.1 and you will be brought to the router's config page where you can setup the wifi's key
Oct 20, 2009 | Linksys Wireless-G Broadband Router
I cont create ip in 8150 pls give me instruction to create ip
You can go to the configuration menu, then look for network config. or network parameters, if ask you for dhcp or manual select manual (or static), then it;s gonna ask you for the ip address, it depends on what you need.
Also here is the documentation:
http://www.scribd.com/doc/4191119/hp-laserjet-8150-users-manual-guide
there is an option for search, you can look for IP Address (I guess that;s what you mean by ip, am I right)
Good Luck.
Apr 25, 2009 | HP LaserJet 8150 Printer
User cannot log on to a web site from our network
please check after disabling javascript/activex filtering on your firewall only for this site.
If you could post me the configuration then it would be really good.
Apr 06, 2009 | Cisco PIX 515E Firewall
User manual for cisco 1800
1800 series is a MSR (Multi Service Router) with that you can build a network with voice,data and enhanced security. In selected models Wireless is also available.
Check the manual in the following link
http://www.cisco.com/en/US/products/ps5853/index.html
Mar 13, 2009 | Computers & Internet
DWA 552 and 2WIRE HP1000
you dont have router protected (is not yours anymore).to gain control again, you can rest config. but you need your router manual nerby, to help you config. a previous internet provider config. and so on. to reset router config, you press a reset button on the back, until the lights is off/red. then config the router on the router website( writen on botton with default user and passw.(user: admin passw: admin or password) the wan config, Wlan,...
(Use a wpa2/wep encrption level on Wlan config.)
Note: change all router passw every 30 days, or less if necessary.
Jul 24, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Find my wep key
Oh, sorry I didn't see it in the title before. First, check the dirvers are properly installed for the adapter. Then if you don't have the wep key, connect by cable or other computer connected to your router (better by cable, as you can have restricted access to router setup menu from wi-fi). The WEP will be in WIFI config. section. If you cant log in to your router, try export the config profile out from another wifi connected PC and import it into new device wifi config software (if they support the same profiles). If nothing of this helped, you can still reset the router (find in manual- most often disconnect from power and push reset button for about 10 seconds) and setup WIFI with new WEP key. Don't forget to write the wep down. If WEP is not your problem but connectivity of the adapter to internet or network at all, describe the problem more deeply
May 28, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
2wire 2700HG-B Router (2700HGB) Logo
203 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
