Question about Vizio VP422 42 in. Plasma TV
Vizio VP422 42in. Plasma Tv power problems
We had an electrical storm last night, now when you plug the tv in it clicks twice and goes off. I can see a green led in the back.
  • Vizio Master
  • 5,568 Answers
The main power supply , which is somewhat active even when the set is 'off,' is damaged.
With luck (a lot of it) it may have gotten enough spike to cause one of the (few) protective parts to fail, rather than serious damage having resulted.
Leave the set upplugged for at least hours (overnight is better) to allow certain components to discharge and remove the back panel from the set. Look for obvious signs of burning/damage and possibley a fuse.
There is a part that limits peak voltages coming in from the AC line that often explodes when hit hard; if not in pieces, it is a disk-like device, mounted vertically with leads coming from the sides or bottom of the disk. If you see only two wires sticking up and going nowhere, that is where the part once was and the damage is probably severe enough to make replacement of the supply necessary and this may not be the end of the repair.
Sorry -
Posted on Jul 26, 2009
Panasonic tv hdmi inputs not working
It appears that during the storm there may have been an electrical surge that damaged the electronics of your tv. If the tuner is working fine then the affected area (board) is the one that has the HDMI input sources.
Aug 30, 2015 | Panasonic Viera TC-P58S1 58 in. Plasma...
Turns on then turns off
check for a bulging capacitors first at the power supply board.
Oct 07, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Thunder storm last night
have u made sure that the out let has power yet? if not check fuse box.
next, if has power to outlet, manually press power button not remote controll, after it has been unplugged for some time. view the back pannel of tv. and see if there is a fuse or fuse notification. follow manufactuar or owners manual instructions from here, google vizio support or call 888 849 4623 with model and info ready
Jul 13, 2012 | Vizio VW32L 32 in. LCD HDTV
Vizio xvt553sv no picture and will shut off
Good evening
Since unplugging will not work, take the remote click on SETUP and go through general as well as picture. See if you cannot make it better.
Good luck
kolbrun
Jul 10, 2012 | Vizio XVT553SV 55 in. LCD TV
Vizio plasma tv will not turn on by button or remote, cable box is lit. We had a loss of power last night due to a storm. What do we do to check it.
hi usually the cause of won't power on problem due to the storm is the current fluctuation which the tendency is power supply failure. now since totally dead set what you need is to open the tv unit then look for the power supply where the power cord is connected. check obvious defective component part like blown fuse and burnt part like resistor and capacitor. just replaced with the same value and ratings to avoid damage from others component.if their is no problem with the power supply the output voltages are good the main board get damaged. good luck thanks for consulting the fixya.
Jul 14, 2011 | Televison & Video
The TV is less than 4 months old and problem started after first month. It powers off for anywhere 3 to 8 minutes. Vizio Logo is flashing until it powers up again. Last night it started after 45 minutes...
Take it back where u bought it exchange it for a new tv.This tv have a major issues,with the board that call the tv Tuner signal board.This is the board the take in the incomming broadcasting signal wire plug into this board to produce a picture out of the incomming broadcasting tv signal.
Apr 02, 2011 | Vizio M470NV 47 in. LCD HDTV
My vizio plasma tv quit, Problem with the
Check ur power source with other devices?Yes.Than,the power supply board it dead.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Oct 23, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
HELP PLEASE Vizio Plasma tv broken again - possible driver board?
This could cause by the power supply or the mainboard.
- If the LED stay Green when you turn on the TV. But you can not turn it off, in this case the main board has failed. Replace the mainboard will fix the problem.
- If the LED light always stay at Orange, you can not turn on of off. In this case the mainboard also has failed.
- If you turn on the TV you will hear the power supply click on the LED is green then it click off the light turn Orange. In this case the power supply has failed.
Which boards did the repair shop replace?
Hope this will help.
Feb 18, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P4 Plasma green blotches
The same thing happened to me Twice!. First time it was under warranty. Now it it out and Vizio has not interest in helping me. The first time the repair man changed the motherboard, which worked for about a year. Looks like I will be buying a new TV soon, but certainly NOT a Vizio, they are junk
Anyone out there know how much a motherboard costs?
Dec 27, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio VP422 42 in. Plasma TV Logo
482 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
