Question about LG 42LC2D 42 in. LCD HDTV
I am buying having 30 min left a lg32inch faulty broken screen 4inch crack damage. the seller is saying it is comes with guarantee and LG will repair but i am not sure that lg guarantee will reapir this cosmetics damage. Can you able to tell me how much will cose to repair screen damage?
  • 34 Answers
The cost of repair will most likely be close to what the HDTV cost brand new. Even if LG did cover it, the glass is often not completely covered by warranty.Broken screens are the worst kind of issues to deal with when considering HDTVs. I would stay away from the actual tv until you get it repaired(health issues). I personally would not recommend buying the tv. If it was so easy to fix, then why didn't the current owner take care of the warranty issue before he decided to sell it?(could have made more $$$)
Posted on Jul 26, 2009
I bought tablet 11/25/14 the inside screen cracked the outside screen did not crack
If the device was broken when you got it, I would recommend returning it to the seller, you have 30 days to do so. If they refuse you can return to the manufacturer within 2 years. If it was broken after you got it, then you will need to get in touch with Samsung directly and they will refer you to an authorized repair center. Going elsewhere will void your warranty.
Jan 11, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
What is problem 2000 mercury outboard 200hp number 5 cyl no compression
if no compression could be a bent , cracked ,damaged valves, hole in piston, broken piston, broken connecting rod,
NO I DONT THINK YOU WANT TO BUY IT .unless its for parts your buying a padoras box of junk ,pull the plug and look it over for damage ,heavy oil ,if your getting no I mean "O" compression you'll have to do a full tare down. to find problem ,if seller says its an eazy or not expencive repair have him do it .
Aug 28, 2014 | Boating
I have a hp dv6 laptop the inside of this screen looks cracked on the inside with ink leaks,outside is not cracked,i canot plug another moniter in as it says very faint in left corner windows canot...
If the screen looks like black ink on the screen then the screen is broken (ie cracked on the inside).
LCD screens and Inverters maybe available from this WEB site.www.lcdparts.net
Mar 11, 2012 | Computers & Internet
LG KP 500 screen knelt upon and so broken
If you were hoping to repair the screen yourself, you would need a lot of highly specialist tools and a (fairly expensive) LCD replacement. If the product is still within warranty you can call LG and claim that the screen cracked of its own accord, in which case they will either repair your phone or have a new one sent out. If it is no longer under warranty, you will still be able to send it to LG, but they will probably charge more than your average high-street repair shop. If it is out of warranty, your only option is to have it repaired at a cost of £50 (on average) if you're in the UK, or $75 state-side. I would post the tech support phone number here, but unfortunately I don't know which country you're from. Hope this helps a little.
Mar 06, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
I am drive a 3and4 km and bike was stop and canot start 30 min and 30 min bad bike is start witch is problem and vich a scilution bike model 2005 and discover 112cc
Hi, Amanrock16 the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or a damaged battery, 9 volts or lower.
2. Faulty alternator/generator and or voltage regulator.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, O2, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Water or dirt in the fuel system, carburetor or filter.
9. . Restricted, blocked or kinked fuel line.
10. Fuel tank empty.
11. The gas cap is not venting properly or fuel tank venting system blocked.
12. A faulty Fuel Pump, pressure regulator and or fuel injectors.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
How to diagnose and recognise starter motor problems
How to diagnose and repair motorcycle charging problems
How to test and repair the charging system on scooter
http://fullmanuals.com/brand/bajaj
http://docsfiles.com/pdf_bajaj_discover_125.html
Oct 16, 2010 | 2005 Bajaj Discover
I accidently left my Samsung Wave Phone in my pocket and was in the washing machine. There also seems to be some sort of crack on the screen too. It starts from the bottom corner and there is a long...
This is a big problem may be your phone will be totally damage.... U will have to repair it....... But my suggestion is that you should by new one instead of repairing it bcez it will cost approx. like buying a new phone and as well as will guaranteed you that it will remain same after few days...so its better to buy a new one.....
Oct 16, 2010 | Cell Phones
Inside screen cracked??
Hello. Take the phone into the phone store and they will repair it for you. Joe
Mar 05, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My screen has cracked
the only thing we can do is to change the LCD for LG KP500. We can't repair the LCD, replacement only
Aug 26, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
My phone (lg kp500) turns on untill the welcome screen
This means the Screen is broken and it is stopling its self from breaking.
This phone is smart you know.
Is there a dent or a crack in the screen ?
Jul 15, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Cracked screen
You can have them repaired but, usually the cost of a new plasma panel exceeds the cost of replacing the set.
Jan 24, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42LC2D 42 in. LCD HDTV Logo
98 people viewed this question
Computer Repairing
Computer Repairing
