Question about Vacuums
Not sucking. motor works.filter cleaned. what could be the reason?
  • yadayada
    yadayada May 11, 2010
    it is very common for the hose to get clogged, blow through it and see if that is the case.
    Problem Solver:
  • 11 Answers
Many vacuums have more than one filter, check the manual to locate the other filters take them out and clean or replace them.
You could have something clogged in a hose or the path to the bag/canister. It sounds like this might be the problem if you are not getting any suction. Check all your airways the dirt travels to find the clog. If you can't get to some places, you may need to take it to a repairman.
Posted on Aug 14, 2009
Hoover not sucking
Remove all filters and try the suction on your hand, NOT THE FLOOR!
Filters are vital to keeping the motor working.
Most vacuum sucking probs are a result of a clogged filter or filters. Sometimes, hoses also. Or a full bag.
Remove all filters, clean them thoroughly, check hose for obstruction.
Use another vacuum to remove dust/dirt (or an air compressor) from the dirty filters.
That's first step.
Feb 26, 2015 | Hoover Vacuums
My Floormate isn't sucking up the water either on the cleaning or the dry cycles. New in February. Can't find my manual.
The most common reason for a lack of pick up is that the plastic filter cover on top of the dirty water recovery tank is missing. The cover is clear plastic with a large hole in it that seals against the motor inlet.
May 16, 2011 | Hoover Vacuums
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Dec 22, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Motor Filter Has Been Sucked In - Eureka 4467AV Upright Vacuum
you will have to remove the cover over the motor so you can get to it and the fan. When you get the filter out, drill holes first, then drive a couple of nails down thru where the filter sits so it can't get sucked into the fan again.
Jun 02, 2008 | Eureka 4467AV Upright Vacuum
Not sucking up
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=34218&thid=565461
Not sucking up
Posted by Smudge935 on May 02, 2008
Hi, I have a Dyson DC05 and initially it sucks up ok then stops. On investigation the dust particles are ending up in the pre-motor filter instead of the canister.
I have checked for blockages, and cleaned filters. Any ideas????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Something is blocking the path of the dirt to the canister and it should not be going directly to the motor filter (diverter valve) that is supposed to be a backup just in case. So that the motor does not burn up, please check with you local vacuum cleaner dealer for a schematic or a product breakdown.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.dyson.com/homepage.asp
Contact Us
1-866-MY-DYSON
(1-866-693-9766)
Dyson Customer Care is available 7 days a week.
· Mon - Fri: 7am - 8pm, CST
· Saturday: 8am - 6pm, CST
· Sunday: 9am - 6pm, CST
questions@dyson.com
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Dyson DC05 Cylinder Bagless Canister...
Shop Vac Model 758.17871
I would suggest it if it gets dirty muddy you can always clean the filter alot easier than replaceing vac
Dec 21, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuum cleaner safety popped
I had same exact problem. It stopped sucking, just spitting out trash back. You need to clean all pipes, all of them. Then take canister apart and clean and wash top filter. It works like new now again
Nov 26, 2007 | Vacuums
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
