Tempstar combo unit PGAD....... 6 years old. Both blower fan and condensor fan are running but no cold air?
    Problem Solver:
  • 6 Answers
You have two copper lines running to outside unit larger one should be cold small one should be at body temp or slightly warm. Is the compressor running?
Posted on Jul 26, 2009
Air conditioning condensor on side of house not working
sounds like you need to check your run cap it is silver in the outside unit and it runs the compressor and fan motor. Check on the capacitor what size it is and replace it for example 45+5 uf.
Sep 07, 2014 | Carrier Heating & Cooling
Why tempstar 5000 High Efficiency a/c outside fan won't turn off ?
Sounds like your contactor is sticking in your outside unit. They could be welded shut.
Jul 21, 2014 | Heating & Cooling
Unit does not stay lit
A few questions for you. If the thermostat is satisfied as in turned below room temp, does the blower shut off. Are the filters clean? Furnaces have a limit control that governs how hot the heat exchanger runs. If the limit switch opens for some reason the fan or blower will continue to run until the limit switch closes. So dirty filters? A very dirty blower wheel? A blower motor that is not coming up to speed, Could just be a bad limit switch that is opening up at a lower temperature than it should. I would also check the pressure switch sensing tube. The end could be blocked with deposits
Sep 06, 2017 | Heating & Cooling
I have a Tempstar 5000 that is about 15 yrs old and the fan motor to the outside unit will suddenly stop working and the compressor will start making a loud humming sound that does not sound too good. I...
Hello
Sounds like the condensor fan motor is going bad.If the fan stops turning or is not turning at full speed, the compressor can not give off heat to the condensor.Which will cause it to shut down on high heat.
So i would start with a new fan motor.Your local heating and cooling supply house should have these in stock.
Aug 01, 2011 | Heating & Cooling
CAN'T PULL OUT THE FUSE ON MY TEMPSTAR 10 C/A UNIT
Hello, if tne outdoor unit is running ( fan and compressor) and the indoor blower motor is running and yet the unit does not cool, then a airflow problem or low refrigerant charge are the problems. Begin by checking the air filter to make sure it is clean and check the blower wheel tommakebsure it is clean and running at proper speed. If the unit is clean then looks like you have a low refrigerant charge due to a leak.
Jul 06, 2011 | Heating & Cooling
Hello...we have a JCD2289AT that is 6 years old approx...frezer and ice maker are working fine butr refrig seems to not hear a cold temerature even after setting to the coldest setting. I pulled the unit...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 19, 2010 | Jenn-Air JSD2789GES Side by Side...
Whirlpool side by side made in 1998 is not cold. freezer side temp ranges between 32 - 40 degrees at coldest setting. coils are clean. blower is working. could thermostat be stuck or freon low? where do...
Most of the time there is an automatic defrosting problem when the freezer starts warming up. Ice builds up on the evporator coils.. airflow gets restricted and the temps warm up. Check to see that your evaporator fan is running at full speed. If it is then do a manual defrost by performing the following steps:
1. Unplug the unit
2. Remove freezer contents
3. Place a fan blowing air into the freezer compartment for a little over 2 hours. (Makes a mess... rags and Mop time)
4. After 2 hours wipe out any residual water...
5, Plug in unit
6. Reload freezer.
7. Check temps in 4 - 5 hours.
If temps are normal you have an Automatic defrost problem.
Causes can be:
1. Defrost timer / control
2. Defrost Heating Element
3. Wiring
There are other causes but timer / control or the element in a 10 + year old unit are the normal failures.
Do this step before the manual defrost
Make sure that the condensor fan in the lower rear part of the unit is running at FULL speed.and that the condensor coils are free of lint and debris. If the condensor and fan are loaded with lint it will cause warmer operating temps. Clean as needed.
If after you do a manual defrost and the temps come back to normal for at least 24 hours you will need to troubleshoot the auto-defrost circuit. If you need help at that time just respond here and I will help you.
Thanks for Choosing FixYa
Kelly
Sep 18, 2010 | Whirlpool Refrigerators
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
Uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Jul 13, 2009 | U-Line Refrigerator Ice Maker
Blower fan keeps shutting on/off,
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
May 31, 2008 | Heating & Cooling
Heating & Cooling Logo
194 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
