Question about Refrigerators
I have a side by side and my water line is leaking from inside the door how can i take it off and find out about the water line in side the door.
  • 76 Answers
This may be bcoz of the rusting of the tube or there may be hole in a tube...this bcoz of the water that comes out the pipe often...since freons are reacting it will easily leads to rusting of the tube...plz call u r service provider for u r fridge...he will take care of that!!!!relax!!!!!!!!
Posted on Jul 26, 2009
Water leaks from bottom of freezer door
You need to remove the door from the refrigerator, then remove from the door the plastic frame carefuly, its snaping, and attach the new (1/4") line to the end of existing line then pull up the existing line softhly until the new one appears, check before all this if the line is broken at then of door or in the middle and if leak is below the refrigerator check from the solenoid to the door.
Jun 13, 2014 | Hotpoint HSS25GFP Side by Side...
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
Have a GE hot point HSS25GFTABB, removed doors to put inside house after a move and the ice maker works, but when you fill with water, it runs down the line dripping at the bottom of left door
Inspect the line crefully at the bottom of the door where it connects to the cabinet supply. The line may have been damaged when and if the doors were removed.
HOPEFULLY it is a small nick in the tubing casuing the water leak, and not the line inside the freezer door as the water line is foamed into the door and the entire door would have to be replaced to resolve an internal leak.
The coupler at the door connection is a push-lock syle coupler and to seperate the line you need to press the white collar into the blue barrel connector to relese the tension.
Jun 14, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water line is freezing inside freezer door.
It sounds like there is a leak and the insulation in the door is wet. If it is real cold on the outside then that is a positive indication the insulation has failed for some reason.
Good Luck,
Gilshultz
Dec 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
Jun 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
