My Dell AIO 962 will not print yellow. Can anyone
My Dell AIO 962 will not print yellow. Can anyone help with this?
  • 5,660 Answers
Suggest you clean the ink cartridge nozzles, and the area on the printer, where the ink cartridge nozzles fit up against.
I'm not referring to using the printers option of cleaning the ink cartridge nozzles. I'm referring
to physically cleaning these two areas.
If a printer sits for a period, and the printing option isn't used very much, the inkjet nozzles can clog with dried ink. The inkjet nozzles have tiny holes, and are almost microscopic in diameter. Clogged inkjet nozzles in this reference are referring to the color option.
The color cartridge.
Perhaps you have used Black a lot, but not the color option lately.
To physically clean these areas you unplug the printer from power. Don protective gloves, (Dish Washing?), to keep any ink from getting on your hands. Use a clean, lint-free cloth saturated in as warm a water, as you can stand to the touch. Then wring the cloth out until it is just damp. Wipe the inkjet holes, (Nozzles), on the ink cartridge in one direction only. Keep wiping until the cloth doesn't pick up ink.
Do the same for the area on the printer, that the inkjets of the cartridge matches up to.
How to know where these areas are?
The inkjets on the cartridge, are located where you took the protective tape off of the cartridge, upon installing. There is a brass strip. The nozzle holes should be located in this strip.
The area on the printer that matches up to the inkjet nozzles of the cartridge, may be readily seen by evidence of ink left behind on this area.
If not, when you remove the ink cartridge, and look at the cartridge, you can judge where the inkjet holes would match up to the area on the printer.
When you are satisfied that both the cartridge inkjet holes are clean, and the area on the printer, let these areas dry.
You can speed up the drying process by using a hair dryer set on low, and constantly moving it back, and forth.
Posted on Jul 26, 2009
  • 202 Answers
Three things i know will cause this
1. is the printer port set correctly, in bios it should be enabled and bidirectional support should be ticked.
2. the connections on the cartridge and holder should be cleaned (turn off and unplug printer, use alchol and q tip to clean. will dry quickly reinsert cart. and try again.
3. clogged color printhead- if it wont clean it may be defective.
good luck hope this helps
Trying to add dell photo AIO 962 printer to my toshiba satellite laptop which is running windows 7. have followed dell website instructions to download driver/firmwear etc and chosen vista 32bit under drop...
Hi! Regarding this matter. The dell photo AIO 962 may not be compatible with windows 7 thats why it gives you the error message. You downloaded the driver using vista32 but you have a windows 7 on you machine, its not gonna work. It may work on the toshiba if you gonna downgrade from windows 7 to vista, but if you dont want that option you can wait for sometime to have an AIO 962 update for windows 7 for it to work. Hope this helps and have a good one!
May 12, 2010 | Office Equipment & Supplies
Having problems downloading drivers for Dell 962
I have a samsung notebook without a place to insert a disc and need to print files from my e-mail using a dell aio 962 printer how do I do this without using the software disc that came with the printer
Jan 26, 2010 | Dell 962 Photo All-In-One InkJet Printer
Dell AOI printer 962 showing error 2200 when trying to scan or copy. I have tried disconnecting and re-installing but have been unable to fix it. Can anyone help ? Mac
go to printers find dell aio 962, right click propertys, check 1st it is set to the right port, usb, paralell which ever the printer uses and that bidirectional support is enabled.same prop. page click advanced and be sure start printing immediately is checked then ok and try printing then. if no prob here then you may have a bad driver, a bad cable or a bad printer.
Jul 26, 2009 | Dell Office Equipment & Supplies
I have a similiar problem with my Dell AIO Printer 962
reinstall the printer and fax cd that came with your computer
Jul 10, 2009 | Dell 962 Photo All-In-One InkJet Printer
Connecting the WGPS606 to Dell AIO 962
Try installing a lower end printer to the same port. For example HP LaserJet 3.
Mar 30, 2009 | NetGear WIRELESS PRINT SERVER 54MBPS...
Can't find Disc 2
Dell.com, click the support tab. Model>Printers>Printers>962>Confirm.
There are all drivers that you need. Any other untilities can probably be found on the site as well.
Apr 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Yellow on all color printings
What photo program do you use? Is the yellow background on all Word doc's? You should check WORD go to the Format|Background make sure "no fill" is selected. You should also check your print properties in control panel and any special program DELL uses. Make sure there isn't some custom setting that is printing the yellow background. Let me know what happens. Good Luck, Tim
Feb 18, 2007 | Dell 962 Photo All-In-One InkJet Printer
182 people viewed this question
k24674
jasbo
jasbo
